View Issue Details [ Jump to Notes ] [ Print ]
0012852ParaView(No Category)public2012-01-09 11:152016-06-17 00:06
Reportertd123
Assigned ToCory Quammen
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version3.12
Target VersionFixed in Version5.1
Summary0012852: Paraview 3.12.0 fails to build against protobuf 2.4.1
DescriptionThis is a repost of http://paraview.org/Bug/view.php?id=12718 [^] since I found out how to switch project types in the bug report.
If I build without protobuf installed, it passes configuration, but then later I get the error:
[ 84%] Generating vtkPVMessage.pb.h, vtkPVMessage.pb.cc
/build/src/ParaView-3.12.0/build/bin/protoc: error while loading shared libraries: libprotoc.so: cannot open shared object file: No such file or directory
which causes:
fatal error: vtkPVMessage.pb.h: No such file or directory
If I install protobuf 2.4.1 on my system and try to compile, I get the following error:
[ 84%] Building CXX object ParaViewCore/ServerImplementation/CMakeFiles/vtkPVServerImplementation.dir/vtkPVSessionBase.cxx.o
In file included from /build/src/ParaView-3.12.0/ParaViewCore/ServerImplementation/vtkSMMessage.h:30:0,
                 from /build/src/ParaView-3.12.0/ParaViewCore/ServerImplementation/vtkPVSessionBase.cxx:22:
/build/src/ParaView-3.12.0/build/ParaViewCore/ServerImplementation/vtkPVMessage.pb.h:12:2: error: #error This file was generated by a newer version of protoc which is incompatible with your Protocol Buffer headers. Please update your headers.
It seems that the configure script should be configured to add support for detecting if protobuf is installed and maybe regenerating the headers if a newer version is installed. I'm building this on archlinux.
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
Attached Filestxt file icon output.txt [^] (1,249,087 bytes) 2012-01-09 11:15
txt file icon output-with-protobuf.txt [^] (1,265,408 bytes) 2012-01-09 11:15
 Relationships
  Notes
(0028327)
slitvinov (reporter)
2012-02-29 01:59
I have the same error on Ubuntu Linux with cmake 2.8.6
"error while loading shared libraries: libprotoc.so: cannot open shared object file: No such file or directory"
I think one way to fix this would be to add LD_LIBRARY_PATH to protoc command.
Here is a relevant cmake file
CMake/ParaViewMacros.cmake
http://paraview.org/gitweb?p=ParaView.git;a=blob_plain;f=CMake/ParaViewMacros.cmake;hb=HEAD [^]
# Function to compile a proto file to generate a .h and .cc file
# Arguments:
# out_cpp_file_variable: variable that gets set with the full path to output file
# in_proto_file: full path to input file (e.g. ${CMAKE_CURRENT_SOURCE_DIR}/foo.pb)
FUNCTION (protobuf_generate out_cpp_file in_proto_file)
  GET_FILENAME_COMPONENT(basename ${in_proto_file} NAME_WE)
  GET_FILENAME_COMPONENT(absolute ${in_proto_file} ABSOLUTE)
  GET_FILENAME_COMPONENT(path ${absolute} PATH)
  SET (out_file ${CMAKE_CURRENT_BINARY_DIR}/${basename}.pb.h)
  SET(${out_cpp_file} ${out_file} PARENT_SCOPE)
  ADD_CUSTOM_COMMAND(
    OUTPUT ${out_file}
    COMMAND protoc_compiler
      --cpp_out=dllexport_decl=VTK_PROTOBUF_EXPORT:${CMAKE_CURRENT_BINARY_DIR}
      --proto_path ${path} ${absolute}
    DEPENDS ${in_proto_file} protoc_compiler
ENDFUNCTION (protobuf_generate)
See example from KDE
http://techbase.kde.org/Development/CMake_FAQ#I_need_to_build_an_executable_which_is_used_later_on_during_the_build_to_generate_files._How_do_I_do_this_.3F [^]
(0034390)
Orion Poplawski (reporter)
2015-04-30 11:51
I think this particular bug can be closed as paraview does build against protobuf 2.4.1 and 2.5.0.
(0035928)
Cory Quammen (developer)
2016-05-06 10:19
This should be closed as indicated by Orion.
 Issue History
2012-01-09 11:15 td123 New Issue
2012-01-09 11:15 td123 File Added: output.txt
2012-01-09 11:15 td123 File Added: output-with-protobuf.txt
2012-02-29 01:59 slitvinov Note Added: 0028327
2015-04-30 11:51 Orion Poplawski Note Added: 0034390
2016-05-06 10:19 Cory Quammen Note Added: 0035928
2016-05-06 10:19 Cory Quammen Status backlog => gatekeeper review
2016-05-06 10:19 Cory Quammen Resolution open => fixed
2016-05-06 10:19 Cory Quammen Assigned To => Cory Quammen
2016-06-17 00:06 Utkarsh Ayachit Status gatekeeper review => customer review
2016-06-17 00:06 Utkarsh Ayachit Fixed in Version => 5.1
2016-06-17 00:06 Utkarsh Ayachit Status customer review => closed
