| 0012898 | ParaView | (No Category) | public | 2012-01-31 19:38 | 2015-01-11 08:35 | ||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | git-master | ||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0012898: Text is truncating incorrectly | ||||||||
| Description | ParaView trunk, remote server, Linux Sources/ Text Use 10000 as your string. Apply. The text isn't being placed in the window correctly. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 12898_fix_text_bounding_box | ||||||||
| Attached Files | ![]() | ||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0028011) Alan Scott (manager) 2012-01-31 19:42 |
Another manifestation of this bug: if you use the following (inside of the quotes) " iii", you get this: ERROR: In /projects/viz/paraview/src/ParaView/3.14.0-junk3/ParaView3/VTK/Filtering/vtkImageData.cxx, line 1530 vtkImageData (0x22144fb0): GetScalarPointer: Pixel (37, 36, 0) not in memory. Current extent= (0, 31, 0, 63, 0, 0) ERROR: In /projects/viz/paraview/src/ParaView/3.14.0-junk3/ParaView3/VTK/Rendering/vtkTextActor.cxx, line 300 vtkTextActor (0x2212f280): Failed rendering text to buffer |
(0028346) Menno Deij (reporter) 2012-03-09 09:11 |
Now try the number '18'. About 20% of the character gets shown to the left of the 1. |
(0028535) Alan Scott (manager) 2012-04-27 16:11 |
Numerous folks are seeing this bug. Changing to high priority. |
(0028569) Utkarsh Ayachit (administrator) 2012-05-03 16:19 |
commit 24da3fc7c6f50a8d563f2a17346e79e364d9f5a0 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu May 3 16:17:06 2012 -0400 BUG 0012898. Fixed occasional clipping of text. Text would get clipped for certain texts. The problem was that the texture coordinate computation did not consider +ve x-offsets for the rendered text. Fixed that. Change-Id: Iac85237b5349255341a735ceb37d57c4d23b6cc1 |
(0028571) Menno Deij (reporter) 2012-05-03 17:01 |
Excellent news. Thanks :-) |
(0028573) Utkarsh Ayachit (administrator) 2012-05-04 12:50 |
merged in master, if applicable. |
(0028789) Alan Scott (manager) 2012-07-17 20:45 |
Tested Linux, remote server, Master. |
| Notes |
| Issue History | |||
| 2012-01-31 19:38 | Alan Scott | New Issue | |
| 2012-01-31 19:41 | Alan Scott | Relationship added | related to 0012355 |
| 2012-01-31 19:42 | Alan Scott | Note Added: 0028011 | |
| 2012-01-31 19:42 | Alan Scott | Status | backlog => todo |
| 2012-03-09 09:11 | Menno Deij | Note Added: 0028346 | |
| 2012-03-09 09:12 | Menno Deij | File Added: 2012-03-09_150925.png | |
| 2012-04-27 16:04 | Alan Scott | Relationship added | has duplicate 0013133 |
| 2012-04-27 16:11 | Alan Scott | Note Added: 0028535 | |
| 2012-04-27 16:11 | Alan Scott | Priority | normal => high |
| 2012-04-27 19:36 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2012-05-03 16:19 | Utkarsh Ayachit | Topic Name | => 12898_fix_text_bounding_box |
| 2012-05-03 16:19 | Utkarsh Ayachit | Note Added: 0028569 | |
| 2012-05-03 16:19 | Utkarsh Ayachit | Status | todo => gatekeeper review |
| 2012-05-03 16:19 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2012-05-03 16:19 | Utkarsh Ayachit | Resolution | open => fixed |
| 2012-05-03 17:01 | Menno Deij | Note Added: 0028571 | |
| 2012-05-04 12:47 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-05-04 12:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-05-04 12:50 | Utkarsh Ayachit | Note Added: 0028573 | |
| 2012-07-17 20:45 | Alan Scott | Note Added: 0028789 | |
| 2012-07-17 20:45 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2015-01-09 14:01 | Chris Harris | Source_changeset_attached | => VTK master 6214dd05 |
| 2015-01-09 14:01 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 24da3fc7 |
| 2015-01-09 14:04 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 3e5c98c1 |
| 2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 7a4bbb58 |
| 2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 9fd2a56d |
| Issue History |
