0012928 | ParaView | (No Category) | public | 2012-02-13 02:45 | 2013-08-05 10:08 | ||||
Reporter | Christian Wohlschlager | ||||||||
Assigned To | |||||||||
Priority | immediate | Severity | minor | Reproducibility | have not tried | ||||
Status | closed | Resolution | duplicate | ||||||
Product Version | 3.12 | ||||||||
Summary | 0012928: Cave Display Problem | ||||||||
Description | Dear Madam and Sir ! cave environment volume display only show part of the ima pvx used: I have two Cave's one 3 Screen : pvx: <?xml version="1.0" ?> <pvx> <Process Type="client"/> <Process Type="server"> <Machine Name="n001" Environment="DISPLAY=:0" LowerLeft= "-2.0 -0.5 -2.0" LowerRight="-0.8 -0.5 -2.0" UpperRight="-0.8 0.5 -2.0" /> <Machine Name="n002" Environment="DISPLAY=:0" LowerLeft= "-1.0 -0.5 -2.0" LowerRight= "0.2 -0.5 -2.0" UpperRight= "0.2 0.5 -2.0" /> <Machine Name="n003" Environment="DISPLAY=:0" LowerLeft= "0.0 -0.5 -2.0" LowerRight= "1.2 -0.5 -2.0" UpperRight= "1.2 0.5 -2.0" /> </Process> </pvx> on one cave 4 walls: <?xml version="1.0" ?> <pvx> <Process Type="client" /> <Process Type="server"> <Machine Name="n005" Environment="DISPLAY=:0" LowerLeft=" -1.2 0 -1.2" LowerRight=" 1.2 0 -1.2" UpperRight=" 1.2 2.4 -1.2" /> <Machine Name="n006" Environment="DISPLAY=:0" LowerLeft=" 1.2 0 -1.2" LowerRight=" 1.2 0 1.2" UpperRight=" 1.2 2.4 1.2" /> <Machine Name="n007" Environment="DISPLAY=:0" LowerLeft= " 1.2 0 1.2" LowerRight="-1.2 0 -1.2" UpperRight="-1.2 2.4 -1.2"/> <Machine Name="n008" Environment="DISPLAY=:0" LowerLeft= "1.2 0 1.2" LowerRight="-1.2 0 1.2" UpperRight= "1.2 0 -1.2"/> </Process> </pvx> the command for starting the server is: /jkudv/packages/openmpi/bin/mpirun -bynode -machinefile /jkuvrc/dv/packages/ParaView-3.12/config/machinefile_cave.txt /jkuvrc/dv/packages/ParaView-3.12/bin/pvserver /jkudv/packages/ParaView-3.12/config/cave.pvx or curved screen: /jkudv/packages/openmpi/bin/mpirun -np 3 -bynode -machinefile /jkudv/packages/ParaView-3.12/config/machinefile_curved.txt /jkudv/packages/ParaView-3.12/bin/pvserver /jkudv/packages/ParaView-3.12/config/curved.pvx starting the client: ./paraview --stereo --stereo-type="Crystal Eyes" 1. Problem cave 4 wall only front is displayed no other screen. 2. Problem curved screen 3 wall sreen are opend correctly ( i can see from the background color ) but displaying a volume only half of the data is displayed. with simple objects ( arrow line etc it works perfectly) see Mail 2/9/2012 5.02 PM From Nikihil Shetty thank you for helping in this issue christian | ||||||||
Project | ParaViewVR | ||||||||
2012-02-13 02:45 | Christian Wohlschlager | New Issue | |
2013-08-05 10:08 | jzarl | Note Added: 0031384 | |
2013-08-05 10:08 | jzarl | Status | backlog => closed |
2013-08-05 10:08 | jzarl | Resolution | open => duplicate |
