0012937ParaView(No Category)public2012-02-14 13:132013-01-10 22:45
ReporterSebastien Jourdain
Assigned ToSebastien Jourdain
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.98.0
Summary0012937: Undo Redo not working for "Zoom to Box" action
DescriptionWhen the camera is modified each position is stored in a custom undo stack which is not the case when we call the "Zoom to Box" function.
TagsNo tags attached.
ProjectTBD
Topic Name12937-undo-redo-zoom-to-box
Typeincorrect functionality
 Relationships
  Notes
(0028286)
2012-02-17 12:22
Merged into git-master, if applicable.
(0028471)
Alan Scott (manager)
2012-04-12 20:51
I just tested this, and it works with undo, but fails with redo. Alan.
(0028813)
2012-07-18 20:51
This now doesn't undo at all.
(0028814)
2012-07-18 20:51
Not working.
(0028841)
Sebastien Jourdain (manager)
2012-07-19 08:18
Hi Alan,
camera changes are not and should not be recorded in the regular Undo/Redo. Instead they are managed by the camera undo/redo that you can find on top of each window toolbar. And that's what is happening with the "Zoom to box" action, you can not Undo them, unless you undo by using those set of window related toolbar button.
Although, while double checking this morning, I've noticed that some RenderView related change get recorded, which seems to be a bug.
Please let me know if you still think it is not working.
(0028843)
2012-07-19 08:50
Ok I've fixed some of the unwanted behavior here: http://www.paraview.org/Bug/view.php?id=13313 [^]
BUT, "Zoom to box" change the center of rotation (I don't know if this is intended or not), and that change get recorded in the main undo/redo stack as it is not a camera position related change.
So depending on what is expected for "Zoom to box" and the "Center of rotation", the behavior is the way it is supposed to be now.
(0029593)
2012-10-30 09:11
Move forward to customer review....
(0029611)
2012-10-31 10:47
merged into master, if applicable.
(0030092)
2013-01-10 22:45
Seems to work correctly.
Tested local server, Windows, master.
 Issue History
2012-02-14 13:13 Sebastien Jourdain New Issue
2012-02-14 13:13 Sebastien Jourdain Assigned To => Sebastiennn Jourdain
2012-02-14 13:13 Sebastien Jourdain Status backlog => todo
2012-02-14 13:14 Sebastien Jourdain Status todo => active development
2012-02-14 14:13 Sebastien Jourdain Topic Name => 12937-undo-redo-zoom-to-box
2012-02-14 14:13 Sebastien Jourdain Status active development => gatekeeper review
2012-02-14 14:13 Sebastien Jourdain Resolution open => fixed
2012-02-17 12:22 Utkarsh Ayachit Fixed in Version => git-master
2012-02-17 12:22 Utkarsh Ayachit Status gatekeeper review => customer review
2012-02-17 12:22 Utkarsh Ayachit Note Added: 0028286
2012-02-20 10:28 Utkarsh Ayachit Fixed in Version git-master => 3.14
2012-04-12 20:51 Alan Scott Note Added: 0028471
2012-07-18 20:51 Alan Scott Note Added: 0028813
2012-07-18 20:51 Alan Scott Note Added: 0028814
2012-07-18 20:51 Alan Scott Status customer review => todo
2012-07-19 08:18 Sebastien Jourdain Note Added: 0028841
2012-07-19 08:50 Sebastien Jourdain Note Added: 0028843
2012-10-30 09:11 Sebastien Jourdain Note Added: 0029593
2012-10-30 09:11 Sebastien Jourdain Status todo => gatekeeper review
2012-10-31 10:46 Utkarsh Ayachit Fixed in Version 3.14 => 3.98.0
2012-10-31 10:47 Utkarsh Ayachit Status gatekeeper review => customer review
2012-10-31 10:47 Utkarsh Ayachit Note Added: 0029611
2013-01-10 22:45 Alan Scott Note Added: 0030092
2013-01-10 22:45 Alan Scott Status customer review => closed
