| 0012951 | ParaView | (No Category) | public | 2012-02-20 17:53 | 2012-10-29 17:04 | ||||
| Product Version | 3.14 | ||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0012951: 6 component arrays not working correctly in Calculartor | ||||||||
| Description | WHen using scalars like Foo_XY, the calculator raises errors. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 12951_fix_calculator | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028314) Utkarsh Ayachit (administrator) 2012-02-21 00:46 |
commit 124164b4abeee86906ad1b678091f661d9ce1b15 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Feb 21 00:44:18 2012 -0500 BUG 0012951. vtkPVArrayCalculator now working for 4-6 components. Calculator UI showed array names as FOO_XX, FOO_XY, etc. however, vtkPVArrayCalculator was not using these names at all. Fixed by ensuring that vtkPVArrayCalculator knows about FOO_XX, FOO_XY, etc. as well as FOO_3, FOO_4, etc. Thus using component numbers is always acceptable. |
(0028454) Alan Scott (manager) 2012-04-11 21:13 |
Tested local server, Linux, 3.14.1. Used sphere, then calculator to make FOO_XX, then another calculator to use FOO_XX. |
| Notes |
| Issue History | |||
| 2012-02-20 17:53 | Utkarsh Ayachit | New Issue | |
| 2012-02-20 17:53 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2012-02-21 00:46 | Utkarsh Ayachit | Topic Name | => 12651_fix_calculator |
| 2012-02-21 00:46 | Utkarsh Ayachit | Note Added: 0028314 | |
| 2012-02-21 00:46 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2012-02-21 00:46 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2012-02-21 00:46 | Utkarsh Ayachit | Resolution | open => fixed |
| 2012-02-24 11:15 | Utkarsh Ayachit | Topic Name | 12651_fix_calculator => 12951_fix_calculator |
| 2012-03-09 14:40 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-03-09 15:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-04-11 21:13 | Alan Scott | Note Added: 0028454 | |
| 2012-04-11 21:13 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| Issue History |
