| 0012972 | ParaView | (No Category) | public | 2012-03-01 11:51 | 2013-05-18 20:00 | ||||
| Reporter | Burlen | ||||||||
| Assigned To | Robert Maynard | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 3.14 | ||||||||
| Target Version | Fixed in Version | 4.0 | |||||||
| Summary | 0012972: duplicated symbols VisIt bridge and PointSprite plugin static linking | ||||||||
| Description | PointSprite plugin and VisIt bridge duplicate have some symbols see ld error output below. This is an important problem because it prevents a static server build from being compatible with KW provided client binaries. #!/bin/bash cmake \ -DCMAKE_BUILD_TYPE=Debug \ -DBUILD_SHARED_LIBS=OFF \ -DBUILD_TESTING=ON \ -DBOOST_ROOT=/work/ext/ParaView/boost_1_47_0 \ -DVTK_USE_BOOST=ON \ -DPARAVIEW_ENABLE_PYTHON=OFF \ -DPARAVIEW_USE_MPI=ON \ -DPARAVIEW_USE_VISITBRIDGE=ON \ -DVISIT_BUILD_READER_CGNS=OFF \ -DVISIT_BUILD_READER_Silo=OFF \ $* Linking CXX executable ../bin/pvdataserver ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `EqualVal<AttributeGroup*>::EqualVector(void*, void*)': /usr/include/c++/4.4/new:101: multiple definition of `EqualVal<AttributeGroup*>::EqualVector(void*, void*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/usr/include/c++/4.4/new:101: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `ConstInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:186: multiple definition of `ConstInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:185: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<int>::InterpScalar(void*, void*, void*, double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:296: multiple definition of `LinInterp<int>::InterpScalar(void*, void*, void*, double)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:295: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<int>::InterpArray(void*, void*, void*, int, double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:306: multiple definition of `LinInterp<int>::InterpArray(void*, void*, void*, int, double)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:305: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<int>::InterpVector(void*, void*, void*, double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:317: multiple definition of `LinInterp<int>::InterpVector(void*, void*, void*, double)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:316: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:359: multiple definition of `LinInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:358: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:137: multiple definition of `AttributeGroup::AttributeGroup(char const*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:128: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CreateTypeMap(char const*)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2256: multiple definition of `AttributeGroup::CreateTypeMap(char const*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2222: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:137: multiple definition of `AttributeGroup::AttributeGroup(char const*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:128: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~AttributeGroup': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:156: multiple definition of `AttributeGroup::~AttributeGroup()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:147: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~AttributeGroup': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:156: multiple definition of `AttributeGroup::~AttributeGroup()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:147: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~AttributeGroup': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:156: multiple definition of `AttributeGroup::~AttributeGroup()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:147: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::NumAttributes() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:177: multiple definition of `AttributeGroup::NumAttributes() const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:168: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::IsSelected(int) const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:208: multiple definition of `AttributeGroup::IsSelected(int) const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:199: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CopyAttributes(AttributeGroup const*)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:239: multiple definition of `AttributeGroup::CopyAttributes(AttributeGroup const*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:230: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::InterpolateConst(AttributeGroup const*, AttributeGroup const*, double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:281: multiple definition of `AttributeGroup::InterpolateConst(AttributeGroup const*, AttributeGroup const*, double)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:269: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::InterpolateLinear(AttributeGroup const*, AttributeGroup const*, double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:446: multiple definition of `AttributeGroup::InterpolateLinear(AttributeGroup const*, AttributeGroup const*, double)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:423: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::EqualTo(AttributeGroup const*) const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:603: multiple definition of `AttributeGroup::EqualTo(AttributeGroup const*) const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:566: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::TypeName() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:754: multiple definition of `AttributeGroup::TypeName() const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:711: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CreateSubAttributeGroup(int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1418: multiple definition of `AttributeGroup::CreateSubAttributeGroup(int)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1402: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::Select(int, void*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1445: multiple definition of `AttributeGroup::Select(int, void*, int)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1429: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SelectField(int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1472: multiple definition of `AttributeGroup::SelectField(int)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1456: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SelectFields(std::vector<int, std::allocator<int> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1498: multiple definition of `AttributeGroup::SelectFields(std::vector<int, std::allocator<int> > const&)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1482: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::UnSelectAll()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1530: multiple definition of `AttributeGroup::UnSelectAll()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1514: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CreateNode(DataNode*, bool, bool)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1564: multiple definition of `AttributeGroup::CreateNode(DataNode*, bool, bool)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1548: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SetFromNode(DataNode*)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1585: multiple definition of `AttributeGroup::SetFromNode(DataNode*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1569: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::ProcessOldVersions(DataNode*, char const*)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1609: multiple definition of `AttributeGroup::ProcessOldVersions(DataNode*, char const*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1593: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::VersionLessThan(char const*, char const*)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1640: multiple definition of `AttributeGroup::VersionLessThan(char const*, char const*)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1624: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::NumAttributesSelected() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1823: multiple definition of `AttributeGroup::NumAttributesSelected() const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1807: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareChar()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2064: multiple definition of `AttributeGroup::DeclareChar()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2039: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2415: multiple definition of `AttributeGroup::typeInfo::typeInfo(unsigned char)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2378: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2423: multiple definition of `AttributeGroup::typeInfo::~typeInfo()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2386: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareUnsignedChar()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2069: multiple definition of `AttributeGroup::DeclareUnsignedChar()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2044: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareInt()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2074: multiple definition of `AttributeGroup::DeclareInt()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2049: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareLong()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2080: multiple definition of `AttributeGroup::DeclareLong()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2055: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareFloat()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2086: multiple definition of `AttributeGroup::DeclareFloat()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2061: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareDouble()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2092: multiple definition of `AttributeGroup::DeclareDouble()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2067: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareString()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2098: multiple definition of `AttributeGroup::DeclareString()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2073: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareAttributeGroup()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2104: multiple definition of `AttributeGroup::DeclareAttributeGroup()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2079: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareBool()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2110: multiple definition of `AttributeGroup::DeclareBool()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2085: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListChar()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2116: multiple definition of `AttributeGroup::DeclareListChar()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2091: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListUnsignedChar()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2122: multiple definition of `AttributeGroup::DeclareListUnsignedChar()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2097: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListInt()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2128: multiple definition of `AttributeGroup::DeclareListInt()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2103: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListLong()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2134: multiple definition of `AttributeGroup::DeclareListLong()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2109: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListFloat()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2140: multiple definition of `AttributeGroup::DeclareListFloat()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2115: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListDouble()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2146: multiple definition of `AttributeGroup::DeclareListDouble()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2121: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListString()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2152: multiple definition of `AttributeGroup::DeclareListString()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2127: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListAttributeGroup()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2158: multiple definition of `AttributeGroup::DeclareListAttributeGroup()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2133: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListBool()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2164: multiple definition of `AttributeGroup::DeclareListBool()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2139: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorBool()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2170: multiple definition of `AttributeGroup::DeclareVectorBool()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2145: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorChar()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2176: multiple definition of `AttributeGroup::DeclareVectorChar()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2151: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorUnsignedChar()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2182: multiple definition of `AttributeGroup::DeclareVectorUnsignedChar()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2157: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorInt()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2188: multiple definition of `AttributeGroup::DeclareVectorInt()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2163: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorLong()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2194: multiple definition of `AttributeGroup::DeclareVectorLong()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2169: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorFloat()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2200: multiple definition of `AttributeGroup::DeclareVectorFloat()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2175: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorDouble()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2206: multiple definition of `AttributeGroup::DeclareVectorDouble()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2181: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorAttributeGroup()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2212: multiple definition of `AttributeGroup::DeclareVectorAttributeGroup()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2187: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorString()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2218: multiple definition of `AttributeGroup::DeclareVectorString()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2193: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SetGuido(int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2389: multiple definition of `AttributeGroup::SetGuido(int)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2352: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetGuido()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2395: multiple definition of `AttributeGroup::GetGuido()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2358: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2399: multiple definition of `AttributeGroup::typeInfo::typeInfo()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2362: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2399: multiple definition of `AttributeGroup::typeInfo::typeInfo()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2362: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2407: multiple definition of `AttributeGroup::typeInfo::typeInfo(AttributeGroup::typeInfo const&)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2370: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2407: multiple definition of `AttributeGroup::typeInfo::typeInfo(AttributeGroup::typeInfo const&)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2370: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2415: multiple definition of `AttributeGroup::typeInfo::typeInfo(unsigned char)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2378: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2423: multiple definition of `AttributeGroup::typeInfo::~typeInfo()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2386: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~typeInfo': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2423: multiple definition of `AttributeGroup::typeInfo::~typeInfo()' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2386: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::typeInfo::operator=(AttributeGroup::typeInfo const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2429: multiple definition of `AttributeGroup::typeInfo::operator=(AttributeGroup::typeInfo const&)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2392: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetFieldName(int) const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2438: multiple definition of `AttributeGroup::GetFieldName(int) const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2401: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetFieldType(int) const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2444: multiple definition of `AttributeGroup::GetFieldType(int) const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2407: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetFieldTypeName(int) const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2475: multiple definition of `AttributeGroup::GetFieldTypeName(int) const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2413: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::FieldsEqual(int, AttributeGroup const*) const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2535: multiple definition of `AttributeGroup::FieldsEqual(int, AttributeGroup const*) const' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2419: first defined here ../bin/libvisitcommon.a(AttributeGroup.C.o): In function `operator<<(std::basic_ostream<char, std::char_traits<char> >&, AttributeGroup const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2571: multiple definition of `operator<<(std::basic_ostream<char, std::char_traits<char> >&, AttributeGroup const&)' ../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2452: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /usr/include/c++/4.4/new:101: multiple definition of `DataNode::bogusString' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/new:101: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:70: multiple definition of `DataNode::bogusCharVector' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:68: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': (.bss+0x30): multiple definition of `DataNode::bogusUnsignedCharVector' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):(.bss+0x30): first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /usr/include/c++/4.4/bits/stl_algobase.h:381: multiple definition of `DataNode::bogusIntVector' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/bits/stl_algobase.h:381: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /usr/include/c++/4.4/bits/stl_vector.h:116: multiple definition of `DataNode::bogusLongVector' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/bits/stl_vector.h:116: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:77: multiple definition of `DataNode::bogusFloatVector' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:75: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:77: multiple definition of `DataNode::bogusDoubleVector' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:75: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /usr/include/c++/4.4/bits/stl_uninitialized.h:81: multiple definition of `DataNode::bogusStringVector' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/bits/stl_uninitialized.h:81: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /usr/include/c++/4.4/new:101: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/new:101: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:70: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:68: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:77: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:75: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:77: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:75: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:84: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:82: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:84: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:82: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:91: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:89: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:91: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:89: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:98: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, long)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:96: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:98: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, long)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:96: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:105: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, float)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:103: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:105: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, float)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:103: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:112: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:110: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:112: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:110: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:119: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:117: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:119: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:117: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:126: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:124: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:126: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:124: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:133: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:131: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:133: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:131: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:146: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:144: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:146: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:144: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:159: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:157: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:159: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:157: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:172: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, long const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:170: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:172: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, long const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:170: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:185: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, float const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:183: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:185: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, float const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:183: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:198: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:196: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:198: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:196: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:211: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:209: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:211: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:209: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:226: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:224: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:226: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:224: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:239: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<char, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:237: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:239: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<char, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:237: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:246: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<unsigned char, std::allocator<unsigned char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:244: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:246: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<unsigned char, std::allocator<unsigned char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:244: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:253: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<int, std::allocator<int> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:251: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:253: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<int, std::allocator<int> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:251: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:260: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<long, std::allocator<long> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:258: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:260: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<long, std::allocator<long> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:258: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:267: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<float, std::allocator<float> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:265: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:267: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<float, std::allocator<float> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:265: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:274: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<double, std::allocator<double> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:272: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:274: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<double, std::allocator<double> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:272: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:281: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:279: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:281: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:279: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `~DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:307: multiple definition of `DataNode::~DataNode()' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:305: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::FreeData()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:327: multiple definition of `DataNode::FreeData()' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:325: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `~DataNode': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:307: multiple definition of `DataNode::~DataNode()' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:305: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsChar() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:509: multiple definition of `DataNode::AsChar() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:507: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsUnsignedChar() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:515: multiple definition of `DataNode::AsUnsignedChar() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:513: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsInt() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:521: multiple definition of `DataNode::AsInt() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:519: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsLong() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:527: multiple definition of `DataNode::AsLong() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:525: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsFloat() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:533: multiple definition of `DataNode::AsFloat() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:531: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsDouble() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:544: multiple definition of `DataNode::AsDouble() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:542: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsString() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:555: multiple definition of `DataNode::AsString() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:553: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsBool() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:564: multiple definition of `DataNode::AsBool() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:562: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsCharArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:570: multiple definition of `DataNode::AsCharArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:568: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsUnsignedCharArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:576: multiple definition of `DataNode::AsUnsignedCharArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:574: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsIntArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:582: multiple definition of `DataNode::AsIntArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:580: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsLongArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:588: multiple definition of `DataNode::AsLongArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:586: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsFloatArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:594: multiple definition of `DataNode::AsFloatArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:592: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsDoubleArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:600: multiple definition of `DataNode::AsDoubleArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:598: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsStringArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:606: multiple definition of `DataNode::AsStringArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:604: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsBoolArray() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:612: multiple definition of `DataNode::AsBoolArray() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:610: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsCharVector() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:618: multiple definition of `DataNode::AsCharVector() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:616: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsUnsignedCharVector() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:627: multiple definition of `DataNode::AsUnsignedCharVector() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:625: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsIntVector() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:636: multiple definition of `DataNode::AsIntVector() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:634: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsLongVector() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:645: multiple definition of `DataNode::AsLongVector() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:643: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsFloatVector() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:654: multiple definition of `DataNode::AsFloatVector() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:652: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsDoubleVector() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:663: multiple definition of `DataNode::AsDoubleVector() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:661: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsStringVector() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:672: multiple definition of `DataNode::AsStringVector() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:670: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetChar(char)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:685: multiple definition of `DataNode::SetChar(char)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:683: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetUnsignedChar(unsigned char)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:693: multiple definition of `DataNode::SetUnsignedChar(unsigned char)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:691: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetInt(int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:701: multiple definition of `DataNode::SetInt(int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:699: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetLong(long)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:709: multiple definition of `DataNode::SetLong(long)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:707: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetFloat(float)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:717: multiple definition of `DataNode::SetFloat(float)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:715: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetDouble(double)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:725: multiple definition of `DataNode::SetDouble(double)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:723: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetString(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:733: multiple definition of `DataNode::SetString(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:731: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetBool(bool)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:741: multiple definition of `DataNode::SetBool(bool)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:739: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetCharArray(char const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:749: multiple definition of `DataNode::SetCharArray(char const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:747: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetUnsignedCharArray(unsigned char const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:764: multiple definition of `DataNode::SetUnsignedCharArray(unsigned char const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:762: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetIntArray(int const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:779: multiple definition of `DataNode::SetIntArray(int const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:777: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetLongArray(long const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:794: multiple definition of `DataNode::SetLongArray(long const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:792: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetFloatArray(float const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:809: multiple definition of `DataNode::SetFloatArray(float const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:807: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetDoubleArray(double const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:824: multiple definition of `DataNode::SetDoubleArray(double const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:822: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetStringArray(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:839: multiple definition of `DataNode::SetStringArray(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:837: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetBoolArray(bool const*, int)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:856: multiple definition of `DataNode::SetBoolArray(bool const*, int)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:854: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetCharVector(std::vector<char, std::allocator<char> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:871: multiple definition of `DataNode::SetCharVector(std::vector<char, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:869: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetUnsignedCharVector(std::vector<unsigned char, std::allocator<unsigned char> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:879: multiple definition of `DataNode::SetUnsignedCharVector(std::vector<unsigned char, std::allocator<unsigned char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:877: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetIntVector(std::vector<int, std::allocator<int> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:887: multiple definition of `DataNode::SetIntVector(std::vector<int, std::allocator<int> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:885: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetLongVector(std::vector<long, std::allocator<long> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:895: multiple definition of `DataNode::SetLongVector(std::vector<long, std::allocator<long> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:893: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetFloatVector(std::vector<float, std::allocator<float> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:903: multiple definition of `DataNode::SetFloatVector(std::vector<float, std::allocator<float> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:901: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetDoubleVector(std::vector<double, std::allocator<double> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:911: multiple definition of `DataNode::SetDoubleVector(std::vector<double, std::allocator<double> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:909: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetStringVector(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:919: multiple definition of `DataNode::SetStringVector(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:917: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AddNode(DataNode*)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1068: multiple definition of `DataNode::AddNode(DataNode*)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1010: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::RemoveNode(DataNode*, bool)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1117: multiple definition of `DataNode::RemoveNode(DataNode*, bool)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1059: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::RemoveNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1186: multiple definition of `DataNode::RemoveNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1128: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetKey() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1241: multiple definition of `DataNode::GetKey() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1183: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetKey(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1247: multiple definition of `DataNode::SetKey(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1189: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetNodeType() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1253: multiple definition of `DataNode::GetNodeType() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1195: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetLength() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1259: multiple definition of `DataNode::GetLength() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1201: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetNumChildren() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1265: multiple definition of `DataNode::GetNumChildren() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1207: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetNumChildObjects() const': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1284: multiple definition of `DataNode::GetNumChildObjects() const' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1226: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetChildren()': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1322: multiple definition of `DataNode::GetChildren()' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1264: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `NodeTypeName(NodeTypeEnum)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1352: multiple definition of `NodeTypeName(NodeTypeEnum)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1294: first defined here ../bin/libvisitcommon.a(DataNode.C.o): In function `GetNodeType(char const*)': /work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1373: multiple definition of `GetNodeType(char const*)' ../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1315: first defined here collect2: ld returned 1 exit status make[2]: *** [bin/pvdataserver] Error 1 make[1]: *** [CommandLineExecutables/CMakeFiles/pvdataserver.dir/all] Error 2 make: *** [all] Error 2 | ||||||||
| Project | TBD | ||||||||
| Topic Name | duplicate_visit_symbols | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029072) Utkarsh Ayachit (administrator) 2012-08-27 09:06 edited on: 2012-08-27 09:06 |
Temporarily, this is overcome by automatically disabling PointSprite plugin compilation when VisIt bridge is ON in git-master. |
(0030584) Utkarsh Ayachit (administrator) 2013-04-19 14:07 |
SUMMARY --------------------------------------------- Topics merged into master: 13060_update_netkarreaderplugin 13842_fix_camera_link_state_loading 14007-add_space_navigator_grab_world_style 14009_MaterialInterfaceFilter_improvement 14010_catalyst_documentation cgns_steady_state duplicate_visit_symbols pvw-fix-doc-external-link pvw-fix-install-rules |
(0030655) Alan Scott (manager) 2013-04-30 20:43 |
Burlen, If this isn't a good enough answer (see Utkarsh's reply below), please reopen this bug. |
| Notes |
| Issue History | |||
| 2012-03-01 11:51 | Burlen | New Issue | |
| 2012-08-27 09:06 | Utkarsh Ayachit | Note Added: 0029072 | |
| 2012-08-27 09:06 | Utkarsh Ayachit | Note Edited: 0029072 | |
| 2013-04-17 17:41 | Robert Maynard | Assigned To | => Robert Maynard |
| 2013-04-17 17:42 | Robert Maynard | Status | backlog => todo |
| 2013-04-17 17:42 | Robert Maynard | Status | todo => active development |
| 2013-04-18 08:59 | Robert Maynard | Topic Name | => duplicate_visit_symbols |
| 2013-04-18 08:59 | Robert Maynard | Status | active development => gatekeeper review |
| 2013-04-18 08:59 | Robert Maynard | Resolution | open => fixed |
| 2013-04-19 14:07 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2013-04-19 14:07 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-04-19 14:07 | Utkarsh Ayachit | Note Added: 0030584 | |
| 2013-04-30 20:43 | Alan Scott | Note Added: 0030655 | |
| 2013-04-30 20:43 | Alan Scott | Status | customer review => closed |
| 2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
| Issue History |
