0012994 | VTK | (No Category) | public | 2012-03-14 03:58 | 2015-01-09 13:53 | ||||
Reporter | nikolay.zhavoronok | ||||||||
Product Version | 5.8.0 | ||||||||
Target Version | Fixed in Version | 6.0.0 | |||||||
Summary | 0012994: vtkXMLMultiBlockDataWriter does not write names for leaf nodes of the multiblock dataset | ||||||||
Description | The following code will assign the name for 0 block, but will not write this name into vtu file: ============================================ vtkNew<vtkUnstructuredGrid> ugrid; vtkNew<vtkMultiBlockDataSet> mb; mb->SetNumberOfBlocks( 1 ); mb->SetBlock( 0, ugrid.GetPointer() ); mb->GetMetaData( 0 )->Set(vtkCompositeDataSet::NAME(), "My Material 1"); mb->GetMetaData( 0 )->Print( std::cout ); // for debuggin to see the name vtkXMLMultiBlockDataWriter *writer = vtkXMLMultiBlockDataWriter::New(); writer->SetInput( mb.GetPointer() ); writer->SetFileName("test.vtm"); writer->Write(); ============================================ The problem is inside vtkXMLMultiBlockDataWriter.cxx, int vtkXMLMultiBlockDataWriter::WriteComposite method iterates over multiblock data set items, and writes names only for vtkCompositeDataSet datasets. The fix looks easy, I am attaching the fixed file. VTK Reader & Paraview support reading of leaf dataset names correctly, so the problem is only in writer. Thanks, Nikolay | ||||||||
Project | TBD | ||||||||
Attached Files | ![]() | ||||||||
(0028407) Utkarsh Ayachit (administrator) 2012-03-29 17:22 |
commit aca416248b949c0bb76863a68914e18b9a009a98 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Mar 29 17:19:50 2012 -0400 BUG 0012994. vtkXMLMultiBlockDataWriter not writing names for leaf nodes. vtkXMLMultiBlockDataWriter was not saving out names for leaf nodes the the mulitblock dataset. Names were only being saved for non-leaf nodes. Fixed that. Change-Id: Ie3ce7e735f7349c517078d4135bc8cb5446486a6 |
(0028408) Utkarsh Ayachit (administrator) 2012-03-29 17:23 |
awaiting gerrit review. |
(0030795) Utkarsh Ayachit (administrator) 2013-05-17 13:53 |
Not sure how the old topic was lost. Adding a new one. Attempt #2: http://review.source.kitware.com/#/t/2775/ [^] |
2012-03-14 03:58 | nikolay.zhavoronok | New Issue | |
2012-03-14 03:58 | nikolay.zhavoronok | File Added: vtkXMLMultiBlockDataWriter.cxx | |
2012-03-29 17:10 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-03-29 17:10 | Utkarsh Ayachit | Status | backlog => tabled |
2012-03-29 17:22 | Utkarsh Ayachit | Note Added: 0028407 | |
2012-03-29 17:23 | Utkarsh Ayachit | Note Added: 0028408 | |
2012-03-29 17:23 | Utkarsh Ayachit | Status | tabled => gatekeeper review |
2012-03-29 17:23 | Utkarsh Ayachit | Resolution | open => fixed |
2013-05-17 13:53 | Utkarsh Ayachit | Note Added: 0030795 | |
2013-07-22 19:39 | Dave DeMarle | Status | gatekeeper review => closed |
2013-07-22 19:39 | Dave DeMarle | Fixed in Version | => 6.0.0 |
2015-01-09 13:48 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 77b0673c |
2015-01-09 13:48 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 3a192370 |
2015-01-09 13:53 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 3f2b5202 |
