0012998 | ParaView | (No Category) | public | 2012-03-14 13:52 | 2016-08-12 09:59 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 3.14 | ||||||||
Summary | 0012998: "Auto Convert Properties" does not extract value range | ||||||||
Description | Edit - Settings - Tick "Auto Convert Properties" Sources - Wavelet - Apply Filters - Random Vectors - Apply Filters - Contour Observe the value range for "BrownianVectors_Magnitude", "BrownianVectors_X", "BrownianVectors_Y", "BrownianVectors_Z": it always states "unlimited" which leads to the defaults for the fields "From" and "To" being set to 0 when hitting the "New Range" button. Likewise when trying to apply the Threshold filter instead of the Contour filter, the lower and upper threshold defaults are set to 0 and 1, respectively, for all auto-extracted vector components. This is opposed to the behaviour requested in closed issue 9146. It does not happen when extracting the vector components manually by means of the Calculator filter. Happens with ParaView 3.10.0-3.14.0 and git/master, Linux x86_64 | ||||||||
Project | TBD | ||||||||
(0036652) Cory Quammen (developer) 2016-08-01 10:06 |
Tested with ParaView 5.1, Mac OS X, built-in client Description Edit - Settings - Tick "Auto Convert Properties" Sources - Wavelet - Apply Filters - Random Vectors - Apply Filters - Threshold The minimum and maximum values are reasonable for BrownianVectors{_X,_Y,_Z,_Magnitude} |
(0038156) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-03-14 13:52 | Sven Buijssen | New Issue | |
2016-08-01 10:06 | Cory Quammen | Note Added: 0036652 | |
2016-08-01 10:06 | Cory Quammen | Status | backlog => customer review |
2016-08-01 10:06 | Cory Quammen | Resolution | open => fixed |
2016-08-01 10:06 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038156 | |
2016-08-12 09:59 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
