0013015ParaView(No Category)public2012-03-20 10:562016-08-12 09:59
ReporterUtkarsh Ayachit
Assigned ToCory Quammen
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version3.14
Summary0013015: Contour corrupting values computed using Python Calculator
Description* Run with pvserver (at least 2 procs)
* Create Wavelet
* Create Python Calculator with expression: global_max(RTData)
* Look at the information tab, the range for "result" is as expected i.e. constant and sensible.
* Now apply Contour (use default values).
* Look at the information tab, the range for "result" is largely bogus.
* If we change the python calculator expression to a constant value e.g. 12, then the result after Contour is still valid.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0036654)
Cory Quammen (developer)
2016-08-01 10:22
No longer seems to be a problem with ParaView 5.1.
* Create Wavelet
* Create Python Calculator with expression: max(RTData) - note, this is different from Utkarsh's original example that used 'global_max', which I believe no longer exists.
* Look at the information tab, the range also as expected.
(0038162)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2012-03-20 10:56 Utkarsh Ayachit New Issue
2016-08-01 10:22 Cory Quammen Note Added: 0036654
2016-08-01 10:22 Cory Quammen Status backlog => customer review
2016-08-01 10:22 Cory Quammen Resolution open => fixed
2016-08-01 10:22 Cory Quammen Assigned To => Cory Quammen
2016-08-12 09:59 Kitware Robot Note Added: 0038162
2016-08-12 09:59 Kitware Robot Status customer review => closed
2016-08-12 09:59 Kitware Robot Resolution fixed => moved
