0013028 | ParaView | (No Category) | public | 2012-03-26 14:56 | 2012-04-11 21:04 | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Product Version | 3.14 | ||||||||
Summary | 0013028: Lighting bug with volume rendering | ||||||||
Description | We have a lighting bug when toggling between volume rendering and solid. Windows, local server, 3.14.0. Open can.exo. change to volume rendering. change back to solid. The lighting won't look right (it will look really dark). It seems to come back when you delete the can, or restart ParaView. | ||||||||
Project | Sandia | ||||||||
(0028393) Utkarsh Ayachit (administrator) 2012-03-26 16:02 |
Another bug I cannot reproduce. What scalar array are you coloring with when you switch to "Volume rendering"? I get EQPS (or GlobalElementId, if I don't enable all arrays) by default and for both I can switch back without any issues. Also, can you try running paraview with "-dr" command line option and see if that affects anything? Wondering if your settings have something setup for lighting that's different from mine. |
(0028452) Alan Scott (manager) 2012-04-11 21:04 |
OK, I am pretty sure that this is consistently happening when I am remote desktop from home. Evidently, there is some bug with the screen scrape. Everything looks fine with ParaView. Tested Linux, local server, 3.14.1. |
2012-03-26 14:56 | Alan Scott | New Issue | |
2012-03-26 16:00 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-03-26 16:00 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2012-03-26 16:00 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-03-26 16:02 | Utkarsh Ayachit | Note Added: 0028393 | |
2012-03-26 16:02 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-04-11 21:04 | Alan Scott | Note Added: 0028452 | |
2012-04-11 21:04 | Alan Scott | Status | customer review => closed |
