0013043 | ParaView | (No Category) | public | 2012-03-29 04:43 | 2016-08-12 09:59 | ||||
Reporter | Jean M. Favre | ||||||||
Product Version | 3.14 | ||||||||
Summary | 0013043: EnSight Gold nsided elements cause segmentation fault | ||||||||
Description | the following test case taken from the EnSight Gold documentation causes ParaView 3.14 to crash when clipping. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | ![]() | ||||||||
(0030351) Jean M. Favre (reporter) 2013-02-19 07:41 |
I have now tried with version 3.98.1 and still see the same crash. |
(0030391) Jean M. Favre (reporter) 2013-02-27 02:53 |
Thanks to a hint by Samuel Key, I thought about trying a much older version. version 3.10 crashes. version 3.8.1 (downloaded the binary ParaView-3.8.1-Linux-x86_64) runs smoothly and is able to clip without crashing. |
(0030876) Laurence Griffiths (reporter) 2013-06-01 06:59 |
I have the same problem - a bad allocation error is raised. I can convert the dataset to a XMLmultiBlockDataSet and the problem still persists. I can repeat the error in 3.98.1 (from the 64-bit linux binary) I can repeat the crash also in vtk-5.10.1 and vtk-6.0.0-rc2 |
(0032391) Laurence Griffiths (reporter) 2014-02-23 14:34 |
I have repeated the test using the data above with paraview 4.1 using the 64-bit linux binary. Clipping now is successful (doesnt crash, and the clip works.) I think this can now be closed. |
(0038172) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-03-29 04:43 | Jean M. Favre | New Issue | |
2012-03-29 04:43 | Jean M. Favre | File Added: EnSighGold.ngons.tar | |
2013-02-19 07:41 | Jean M. Favre | Note Added: 0030351 | |
2013-02-27 02:53 | Jean M. Favre | Note Added: 0030391 | |
2013-06-01 06:59 | Laurence Griffiths | Note Added: 0030876 | |
2014-02-23 14:34 | Laurence Griffiths | Note Added: 0032391 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038172 | |
