| 0013045 | ParaView | (No Category) | public | 2012-03-29 11:29 | 2016-08-12 09:59 | ||||
| Reporter | grenon | ||||||||
| Assigned To | Kitware Robot | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 3.14 | ||||||||
| Summary | 0013045: Clip on Extract Subset crashes when Extract Subset reduces to a surface | ||||||||
| Description | - Load a structured IJK domain (Tecplot reader or else), indexes I = 0 to Imax, J = 0 to Jmax and K = 0 to Kmax - Add the "Extract subset" filter to get the surface J=0, so subset indexes are I = 0 to Imax, J = 0 to 0 and K = 0 to Kmax - Add the "Clip" filter with plane Z=something or else => paraview crashes !!! Workaround: after the "Extract Subset" filter, add the "Extract Surfaces" filter, then the "Clip" filter and clipping is OK ! | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0038173) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2012-03-29 11:29 | grenon | New Issue | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038173 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
