| 0013054 | ParaView | (No Category) | public | 2012-04-03 16:51 | 2013-01-28 18:25 | ||||
| Reporter | Orion Poplawski | ||||||||
| Status | closed | Resolution | no change required | ||||||
| Product Version | |||||||||
| Target Version | 3.98.1 | Fixed in Version | 3.98.0 | ||||||
| Summary | 0013054: Build kwProcessXML as forwarded executable even if CMAKE_SKIP_RPATH is off | ||||||||
| Description | Debian and Fedora need this patch for ksProcessXML to work in installed package. See https://bugzilla.redhat.com/show_bug.cgi?id=808490 [^] | ||||||||
| Project | TBD | ||||||||
| Topic Name | 13054_fix_processxml | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028480) Utkarsh Ayachit (administrator) 2012-04-13 14:42 |
commit 15a314b9a6a2527c99f88128ffeac2e10edd9035 Author: Mathieu Malaterre <mathieu.malaterre@gmail.com> Date: Fri Apr 13 14:41:34 2012 -0400 BUG 0013054. 0013054: Build kwProcessXML as forwarded executable always. This patch forces building of kwProcessXML as shared forwarded executable in our case (even is CMAKE_SKIP_RPATH is OFF in debian) |
(0028494) Utkarsh Ayachit (administrator) 2012-04-20 13:51 |
merged into master, where applicable. |
(0028815) Alan Scott (manager) 2012-07-18 20:52 |
Programmer tag in the bug tracker. Closing. |
(0029838) Orion Poplawski (reporter) 2012-12-06 17:34 |
This appears to be broken again with paraview 3.98.0 |
(0029854) Orion Poplawski (reporter) 2012-12-07 13:20 |
This patch doesn't work - it removes the rpath but it isn't installed as a forwarded executable. Any help would be greatly appreciated. |
(0029896) Orion Poplawski (reporter) 2012-12-17 11:51 |
This gets a little closer, but I end up with both kwProcessXML and vtkkwProcessXML in /usr/bin, and vtkkwProcessXML in /usr/lib/paraview, so I don't know where the renaming is happening. |
(0030270) Orion Poplawski (reporter) 2013-01-28 18:25 |
rpath seems to be acceptable in this case for Fedora, so closing. |
| Notes |
| Issue History | |||
| 2012-04-03 16:51 | Orion Poplawski | New Issue | |
| 2012-04-03 16:51 | Orion Poplawski | File Added: paraview-kwprocessxml_rpath.patch | |
| 2012-04-13 14:42 | Utkarsh Ayachit | Topic Name | => 13054_fix_processxml |
| 2012-04-13 14:42 | Utkarsh Ayachit | Note Added: 0028480 | |
| 2012-04-13 14:42 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2012-04-13 14:42 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2012-04-13 14:42 | Utkarsh Ayachit | Resolution | open => fixed |
| 2012-04-13 14:42 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2012-04-20 13:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-04-20 13:51 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-04-20 13:51 | Utkarsh Ayachit | Note Added: 0028494 | |
| 2012-07-18 20:52 | Alan Scott | Note Added: 0028815 | |
| 2012-07-18 20:52 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2012-12-06 17:34 | Orion Poplawski | Note Added: 0029838 | |
| 2012-12-06 17:34 | Orion Poplawski | Status | closed => backlog |
| 2012-12-06 17:34 | Orion Poplawski | Resolution | fixed => reopened |
| 2012-12-07 10:25 | Orion Poplawski | File Added: paraview-3.98.0-kwprocessxml_rpath.patch | |
| 2012-12-07 13:20 | Orion Poplawski | Note Added: 0029854 | |
| 2012-12-17 11:49 | Orion Poplawski | File Added: paraview-kwprocessxml_rpath-2.patch | |
| 2012-12-17 11:51 | Orion Poplawski | Note Added: 0029896 | |
| 2012-12-18 05:12 | Utkarsh Ayachit | Target Version | => 4.0 |
| 2013-01-28 16:25 | Utkarsh Ayachit | Target Version | 4.0 => 3.98.1 |
| 2013-01-28 18:25 | Orion Poplawski | Note Added: 0030270 | |
| 2013-01-28 18:25 | Orion Poplawski | Status | backlog => closed |
| 2013-01-28 18:25 | Orion Poplawski | Resolution | reopened => no change required |
| Issue History |
