0013079ParaView(No Category)public2012-04-10 17:012012-10-29 17:04
ReporterUtkarsh Ayachit
Assigned ToSebastien Jourdain
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.98.0
Summary0013079: Provide equivalent to the "s" key to put you in node selection mode.
Description Provide equivalent to the "s" key to put you in node selection mode. (maybe "n" for node selection mode, "e" for element selection mode).
TagsNo tags attached.
ProjectINL
Topic Name13079-add-selection-hot-key
Typeincorrect functionality
 Relationships
  Notes
(0028657)
Sebastien Jourdain (manager)
2012-05-29 16:22
The mapping of the actions in the toolbar will follow the keyboard layout.
Meaning on the keyboard we have the following letters: sdfg and bn which will map with
s[select surface cells]
d[select points]
f[select frustum cells]
g[select frustum points]
b[select block]
n[pick object]
(0028666)
2012-06-01 14:41
Merged in master, if applicable.
(0028944)
Alan Scott (manager)
2012-07-25 20:17
Tested local server, Linux, master.
 Issue History
2012-04-10 17:01 Utkarsh Ayachit New Issue
2012-04-17 12:40 Utkarsh Ayachit Assigned To => Sebastiennn Jourdain
2012-05-29 16:11 Sebastien Jourdain Status backlog => todo
2012-05-29 16:11 Sebastien Jourdain Status todo => active development
2012-05-29 16:22 Sebastien Jourdain Note Added: 0028657
2012-05-29 17:43 Sebastien Jourdain Topic Name => 13079-add-selection-hot-key
2012-05-29 17:43 Sebastien Jourdain Status active development => gatekeeper review
2012-05-29 17:43 Sebastien Jourdain Resolution open => fixed
2012-06-01 14:40 Utkarsh Ayachit Fixed in Version => git-master
2012-06-01 14:41 Utkarsh Ayachit Status gatekeeper review => customer review
2012-06-01 14:41 Utkarsh Ayachit Note Added: 0028666
2012-07-25 20:17 Alan Scott Note Added: 0028944
2012-07-25 20:17 Alan Scott Status customer review => closed
2012-10-29 17:04 Utkarsh Ayachit Fixed in Version git-master => 3.98.0
