0013087 | ParaView | Feature | public | 2012-04-13 09:59 | 2015-01-11 08:35 | ||||
Reporter | Ian Curington | ||||||||
Product Version | 3.14.1 | ||||||||
Target Version | 4.0 | Fixed in Version | 3.98.0 | ||||||
Summary | 0013087: Enable mapping PipelineSource with vtkActor names with 1-line patch adding inspector | ||||||||
Description | Please urgently add to: ParaView-3.14.0/ParaViewCore/ClientServerCore/vtkGeometryRepresentation.h line 185: vtkPVLODActor* GetActor(){return Actor;} SUMMARY: Request to add inspector routine to vtkGeometryRepresentation class to allow creating mapping of pqPipelineSource with vtkActor (from vtkRenderWindow) instances necessary in any 3D scene graph capturing Plugin. Such mapping allows captured scene graph (VTK, X3D, PDF3D, etc) to include meaningful originating Pipeline names. DESCRIPTION: To export ParaView scene to 3D PDF or other similar full scene-graph systems with properly mapped names of pipeline sources with model tree names, mapping between pqPipelineSource and vtkActor (from vtkRenderWindow) instances needs to be created in the exporting plugin. One-line Inspector routine is added to the class to enable our plugin to calculate which vtkActor objects are represented by which pqPipelineSource objects, which is used later, to set model tree names, during exporting vtkRenderWindow's content to 3D PDF. This patch is very important to us because 3D pdf files we generate, with correct model tree names, are much more user friendly and allow to user to exactly know which path of 3D scene was exported from which part of ParaView scene. EXAMPLE CODE SNIPPET of USE, in PLUGIN: // // This code snippet describes how ACTORS NAME PATCH is used in // PDF3D ParaView Plugin. // // Following code retrieves list of pipeline sources currently // managed by ParaView's Server Manager and for each: // // 1. Retrieves coresponding data representation used for it's // displaying, // 2. If pipeline source is visible (i.e. data representation is // visible), it saves mapping (routine AddNameMapping) between // pipeline source's name and vtkActor's instance object which // is added to vtkRenderWindow. // // get reference to application's object pqApplicationCore* application = pqApplicationCore::instance(); // get reference to server manager model's object pqServerManagerModel* server_manager_model = application->getServerManagerModel(); // get all sources QList<pqPipelineSource*> sources = server_manager_model->findItems<pqPipelineSource*>(); // pass through all sources and initialize name mapping int i; for(i = 0; i < sources.size(); i++) { // get source pqPipelineSource* source = sources.at(i); // get representation pqDataRepresentation* representation = source->getRepresentation(active_view); if(representation == NULL || !representation->isVisible()) continue; // get client side representation object - composite representation vtkPVCompositeRepresentation* composite_representation = dynamic_cast<vtkPVCompositeRepresentation*>(representation->getProxy()->GetClientSideObject()); if(composite_representation != NULL) { // get currently active geometry representation and set name for its appropriate actor vtkGeometryRepresentation* active_representation = dynamic_cast<vtkGeometryRepresentation*>(composite_representation->GetActiveRepresentation()); if(active_representation != NULL) AddNameMapping(active_representation->GetActor(), source->getSMName().toAscii().data()); } } | ||||||||
Project | ParaViewPro | ||||||||
Topic Name | 13087_extend_representation_api | ||||||||
Type | usability | ||||||||
(0028477) Ian Curington (reporter) 2012-04-13 11:34 |
This one is actually very important to our project, as without it, we can only generate saved scenes with vtkActor#1, vtkActor#2, ..., instead of "Slice","Streamline", etc. As far as we are aware, this is benign change, does not change any current behaviour, and should not break any other dependent layers, i.e., is pure add. |
(0028840) Ian Curington (reporter) 2012-07-19 06:37 |
Do you have rough idea when this will be addressed, i.e. for 4.0 alpha? |
(0029027) Ian Curington (reporter) 2012-08-17 15:39 |
Clarification of patch location in current development: ParaView.Git\ParaView\ParaViewCore\ClientServerCore\Rendering\vtkGeometryRepresentation.h line 173, in current Git Master as of 17 August 2012. Please add the single line: vtkPVLODActor* GetActor(){return Actor;} Thanks in advanced, much appreciated. -Ian |
(0029500) Utkarsh Ayachit (administrator) 2012-10-24 11:14 |
commit e55d00d66dbe9236865e0ce4a08c9ed8d3701adc Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 24 11:13:01 2012 -0400 BUG 0013087. Added API to access the actor used by vtkGeometryRepresentation. Change-Id: If57fe462e55a9a85b37723d4eb3888bd92b4ad2e |
(0029523) Ian Curington (reporter) 2012-10-26 08:05 |
Thank you Utkarsh! I thought I had added another note, but it seems to have been lost. We need exactly the same patch also in vtkImageSliceRepresentation.h line 117: // Description: // Used in ConvertSelection to locate the prop used for actual rendering. virtual vtkPVLODActor* GetRenderedProp() { return this->Actor; } Can I ask you to kindly reopen and make this change also? Very sorry my previous note seems to have not been recorded. Best Regards, Ian |
(0029524) Utkarsh Ayachit (administrator) 2012-10-26 10:06 |
commit 16e0bcfd8f8c4630abbc3420b6e0af8b4e7f3584 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Oct 26 10:04:54 2012 -0400 BUG 0013087. Added API to access the actor defined in various representations. Change-Id: I3c0185145353d3f3a85bd35b5524596d3b63aeb4 |
(0029525) Ian Curington (reporter) 2012-10-26 10:10 |
Thank you very much! |
(0029526) Utkarsh Ayachit (administrator) 2012-10-26 10:11 |
no problem at all! |
(0029546) Utkarsh Ayachit (administrator) 2012-10-29 10:50 |
merged into master, if applicable. |
(0030180) Alan Scott (manager) 2013-01-17 19:17 |
Closing, as original reporter states it is fixed. Trusting Ian and Utkarsh. |
2012-04-13 09:59 | Ian Curington | New Issue | |
2012-04-13 11:34 | Ian Curington | Note Added: 0028477 | |
2012-04-23 10:33 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-04-23 10:33 | Utkarsh Ayachit | Status | backlog => todo |
2012-04-23 10:33 | Utkarsh Ayachit | Category | (No Category) => Feature |
2012-04-23 10:41 | Utkarsh Ayachit | Project | TBD => ParaViewPro |
2012-07-19 06:37 | Ian Curington | Note Added: 0028840 | |
2012-08-17 15:39 | Ian Curington | Note Added: 0029027 | |
2012-10-18 14:11 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-10-24 11:14 | Utkarsh Ayachit | Topic Name | => 13534_fix_clip_planes |
2012-10-24 11:14 | Utkarsh Ayachit | Note Added: 0029500 | |
2012-10-24 11:14 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-10-24 11:14 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-24 11:14 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-26 08:05 | Ian Curington | Note Added: 0029523 | |
2012-10-26 10:00 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2012-10-26 10:00 | Utkarsh Ayachit | Resolution | fixed => reopened |
2012-10-26 10:06 | Utkarsh Ayachit | Topic Name | 13534_fix_clip_planes => 13087_extend_representation_api |
2012-10-26 10:06 | Utkarsh Ayachit | Note Added: 0029524 | |
2012-10-26 10:06 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-26 10:06 | Utkarsh Ayachit | Resolution | reopened => fixed |
2012-10-26 10:10 | Ian Curington | Note Added: 0029525 | |
2012-10-26 10:11 | Utkarsh Ayachit | Note Added: 0029526 | |
2012-10-29 10:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-29 10:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-29 10:50 | Utkarsh Ayachit | Note Added: 0029546 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-17 19:17 | Alan Scott | Note Added: 0030180 | |
2013-01-17 19:17 | Alan Scott | Status | customer review => closed |
2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 77ee8f9b |
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 16e0bcfd |
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master e55d00d6 |
