0013104 | ParaView | (No Category) | public | 2012-04-18 16:48 | 2016-08-12 09:59 | ||||
Reporter | l_r_mcglashan | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 3.14.1 | ||||||||
Summary | 0013104: Unable to glyph vectors read from an OBJ file | ||||||||
Description | Put the following into an OBJ file and load it into paraview: v 0 0 0 vn 1 1 1 Selecting the glyph filter results in vectors that are always aligned with the x-axis. If the loaded file is then saved as a .vtk or .vtp file, they can then be loaded in and glyphed successfully. So it appears that the vector normal data is loaded into paraview from a .obj file, because it can be saved successfully into other formats. | ||||||||
Project | TBD | ||||||||
Attached Files | test-vectorNormals.obj [^] (17 bytes) 2012-04-25 04:41 | ||||||||
(0028512) Utkarsh Ayachit (administrator) 2012-04-23 10:17 |
Can you attach a sample file please? |
(0036660) Cory Quammen (developer) 2016-08-02 10:17 |
This works fine. You need to set the Vectors setting to Normals under Active Attributes. Tested on ParaView 5.1, Mac OS X, built-in server. Launch ParaView Load attached OBJ file test-vectorNormals.obj Add Glyph filter Set Vectors to "Normals" and make sure the Orient checkbox is checked. |
(0038194) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-04-18 16:48 | l_r_mcglashan | New Issue | |
2012-04-23 10:17 | Utkarsh Ayachit | Note Added: 0028512 | |
2012-04-25 04:41 | l_r_mcglashan | File Added: test-vectorNormals.obj | |
2016-08-02 10:17 | Cory Quammen | Note Added: 0036660 | |
2016-08-02 10:17 | Cory Quammen | Status | backlog => customer review |
2016-08-02 10:17 | Cory Quammen | Resolution | open => fixed |
2016-08-02 10:17 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038194 | |
2016-08-12 09:59 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
