0013120 | ParaView | (No Category) | public | 2012-04-24 02:57 | 2012-10-29 17:04 | ||||
Reporter | Zhan | ||||||||
Assigned To | Sebastien Jourdain | ||||||||
Product Version | 3.14 | ||||||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013120: Paraview crashed when deleting an added python macro from Macro Menu | ||||||||
Description | I have compiled ParaView 3.10.1 and 3.14.0 as 32bit on Windows 7 with MS VS 2008, and I found it would crash when I tried to delete a macro I added. After debugging for some time, I found there's bug in the following codes: for ( ; itr != this ->Internal->DeleteActionMap.constEnd(); ++itr ) { if (itr.value() == action) { QString filename = itr.key(); pqPythonMacroSupervisor::removeStoredMacro(filename); pqPythonMacroSupervisor::removeMacro(filename); } } QMap's removing actions has different behavior on VS Compiler, and removing one element in this loop would cause dangling pointer problem. I have changed the codes to the following(do not increment in for clauses) to fix this bug: for ( ; itr != this->Internal->DeleteActionMap.constEnd();) { if (itr.value() == action) { QString filename = (itr++).key(); pqPythonMacroSupervisor::removeStoredMacro(filename); pqPythonMacroSupervisor::removeMacro(filename); } else { ++itr; } } | ||||||||
Project | Release | ||||||||
Topic Name | 13120-fix-delete-macro | ||||||||
Type | crash | ||||||||
(0028744) Lawrence (reporter) 2012-07-05 14:38 |
I noticed pqPythonMacroSupervisor::removeMacro calls this->Internal->DeleteActionMap.remove(fileName) so is the iterator even still guaranteed to be valid? |
(0028754) Lawrence (reporter) 2012-07-06 11:59 |
The following is a more robust fix. (Started with 3.14.1 code, Fixes Dangling Iterator problem. Tested on Win7 64bit build of 3.14.1 - deleting macros no longer crashes Paraview) void pqPythonMacroSupervisor::onDeleteMacroTriggered() { QObject* action = this->sender(); QMap<QString, QPointer<QAction> >::const_iterator itr = this->Internal->DeleteActionMap.constBegin(); // (A more paranoid version would restart the iterator using DeleteActionMap.constBegin()). while( itr != this->Internal->DeleteActionMap.constEnd()) { if (itr.value() == action) { QString filename = itr.key(); ++itr; // Avoid dangling iterator; increment iterator before removeMacro modifies DeleteActionMap // "If you remove items from the map, iterators that point to the removed items will become dangling iterators." // - http://qt-project.org/doc/qt-5.0/qmap-iterator.html [^] , potentially causing a crash pqPythonMacroSupervisor::removeStoredMacro(filename); pqPythonMacroSupervisor::removeMacro(filename); } else { ++itr; } } } |
(0028898) Utkarsh Ayachit (administrator) 2012-07-24 10:48 |
merged into master, if applicable. |
(0028935) Alan Scott (manager) 2012-07-25 14:55 |
Internal code fix. Closing. (Note that there really isn't enough information here to test.) |
2012-04-24 02:57 | Zhan | New Issue | |
2012-07-05 14:38 | Lawrence | Note Added: 0028744 | |
2012-07-06 11:59 | Lawrence | Note Added: 0028754 | |
2012-07-19 09:10 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain |
2012-07-19 09:10 | Sebastien Jourdain | Topic Name | => 13120-fix-delete-macro |
2012-07-19 09:10 | Sebastien Jourdain | Status | backlog => gatekeeper review |
2012-07-19 09:10 | Sebastien Jourdain | Resolution | open => fixed |
2012-07-24 10:47 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-07-24 10:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-07-24 10:48 | Utkarsh Ayachit | Note Added: 0028898 | |
2012-07-25 14:55 | Alan Scott | Note Added: 0028935 | |
2012-07-25 14:55 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
