0013138 | ParaView | (No Category) | public | 2012-04-27 08:19 | 2016-08-12 09:59 | ||||
Reporter | Igor | ||||||||
Product Version | 3.14.1 | ||||||||
Summary | 0013138: dataserver+renderserver not able to process data | ||||||||
Description | I run dataserver and renderserver (in simplest case on same machine, but in production we will use cluster for data processing and a few servers to show rendered results) at linux server (cenos 5.7). And connect to them by remote client (linux workstation). After connection i may see on display of renderserver Paraview screen and may rotate axis. When i try to add some object in client (sphere, for example) and press apply button nothing changed on renderserver display, but client hangs and not able to do anything. tcpdump shows that after client connection data and render server not send any data to each other due to client disconnect. In case of using pvserver instead of pvdataserver+pvrenderserver all works fine. | ||||||||
Project | Release | ||||||||
(0038206) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-04-27 08:19 | Igor | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038206 | |
