| 0013140 | ParaView | (No Category) | public | 2012-04-29 16:55 | 2012-10-29 23:43 | ||||
| Reporter | George Zagaris | ||||||||
| Assigned To | George Zagaris | ||||||||
| Product Version | git-master | ||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013140: Properly expose AMR plane-cutter in ParaView UI | ||||||||
| Description | 1. Load VTKData/Data/AMR/Enzo/DD0010 2. Select all fields and set maximum level to 8 3. Apply 4. Navigate to Filters->AMR->AMR CutPlane The AMR CutPlane is disabled. This is b/c in the XML descriptor the input type is set to vtkHierarchicalBoxDataSet while the data is an instance of vtkOverlappingAMR. | ||||||||
| Project | TBD | ||||||||
| Topic Name | amr-plane-cutter | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028539) George Zagaris (developer) 2012-04-29 17:01 |
Fixed in 613b445 |
(0028553) Utkarsh Ayachit (administrator) 2012-04-30 10:00 |
merged into master (if applicable) |
(0029588) Alan Scott (manager) 2012-10-29 23:43 |
Tested remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2012-04-29 16:55 | George Zagaris | New Issue | |
| 2012-04-29 16:55 | George Zagaris | Assigned To | => George Zagaris |
| 2012-04-29 17:01 | George Zagaris | Topic Name | => amr-plane-cutter |
| 2012-04-29 17:01 | George Zagaris | Note Added: 0028539 | |
| 2012-04-29 17:01 | George Zagaris | Status | backlog => gatekeeper review |
| 2012-04-29 17:01 | George Zagaris | Resolution | open => fixed |
| 2012-04-30 09:50 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-04-30 10:00 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-04-30 10:00 | Utkarsh Ayachit | Note Added: 0028553 | |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2012-10-29 23:43 | Alan Scott | Note Added: 0029588 | |
| 2012-10-29 23:43 | Alan Scott | Status | customer review => closed |
| Issue History |
