0013150ParaView(No Category)public2012-05-04 09:292012-10-29 17:04
ReporterUtkarsh Ayachit
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.98.0
Summary0013150: Simplify "Find Data" dialog
DescriptionSimplify "Find Data" dialog. User's are finding it hard to write expressions.
TagsNo tags attached.
ProjectSandia
Topic Name13150-add-simpler-ui-for-findData
Typefeature
 Relationships
related to 0013225closedSebastien Jourdain Crash Bug/Bad Memory Read in pqQueryDialog (vtkDataObjectTypes::GetClassNameFromTypeId also partly to blame)
related to 0010955closedAlan Scott Find/Edit data command - turn text on/off
related to 0010958closedUtkarsh Ayachit Edit/Find data command - find and calculate min and max variable for each time step of an animation
related to 0010956closedUtkarsh Ayachit Find/Edit data command - ability to click on a cell or point, highlighted on
  Notes
(0028956)
2012-07-27 14:43
merged into master, if applicable.
(0028974)
2012-08-07 14:28
(Seb, can you add a screen shot or some explaination for what this task did and how to test it? Thanks).
(0028975)
Sebastien Jourdain (manager)
2012-08-07 14:33
This should bring back the old FindDialog option with the list of fields in the combobox instead of having only the "Query" choice.
Moreover, after executing the findData, if you switch to query, you can see what your setup match to the query syntax.
(0028996)
2012-08-10 15:49
Seems to be properly in Master now...
(0029018)
2012-08-17 14:27
merged in master, if applicable
(0029242)
Alan Scott (manager)
2012-09-20 17:19
Interface has been simplified. Still need other features, such as min and max.
 Issue History
2012-05-04 09:29 Utkarsh Ayachit New Issue
2012-05-04 09:29 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2012-05-04 09:33 Utkarsh Ayachit Assigned To Utkarsh Ayachit => Kyle Lutz
2012-05-22 19:26 Alan Scott Relationship added related to 0010955
2012-05-22 19:27 Alan Scott Relationship added related to 0010958
2012-05-22 19:28 Alan Scott Relationship added related to 0010956
2012-05-31 10:23 Utkarsh Ayachit Status backlog => todo
2012-06-19 16:35 Utkarsh Ayachit Assigned To Kyle Lutz => Sebastiennn Jourdain
2012-06-20 10:58 Utkarsh Ayachit Relationship added related to 0013225
2012-07-18 11:21 Sebastien Jourdain Status todo => active development
2012-07-25 18:53 Sebastien Jourdain Topic Name => 13150-add.... don't remember....
2012-07-25 18:53 Sebastien Jourdain Status active development => gatekeeper review
2012-07-25 18:53 Sebastien Jourdain Resolution open => fixed
2012-07-27 14:42 Utkarsh Ayachit Fixed in Version => git-master
2012-07-27 14:43 Utkarsh Ayachit Status gatekeeper review => customer review
2012-07-27 14:43 Utkarsh Ayachit Note Added: 0028956
2012-08-01 17:38 Sebastien Jourdain Status customer review => active development
2012-08-01 17:39 Sebastien Jourdain Topic Name 13150-add.... don't remember.... => 13150-add-simpler-ui-for-findData
2012-08-01 17:39 Sebastien Jourdain Status active development => gatekeeper review
2012-08-07 14:28 Utkarsh Ayachit Note Added: 0028974
2012-08-07 14:33 Sebastien Jourdain Note Added: 0028975
2012-08-10 15:49 Sebastien Jourdain Assigned To Sebastien Jourdain => Utkarsh Ayachit
2012-08-10 15:49 Sebastien Jourdain Note Added: 0028996
2012-08-17 14:27 Utkarsh Ayachit Status gatekeeper review => customer review
2012-08-17 14:27 Utkarsh Ayachit Note Added: 0029018
2012-09-20 17:19 Alan Scott Note Added: 0029242
2012-09-20 17:19 Alan Scott Status customer review => closed
2012-10-29 17:04 Utkarsh Ayachit Fixed in Version git-master => 3.98.0
