View Issue Details [ Jump to Notes ] | [ Print ] |
0013173 | ParaView | (No Category) | public | 2012-05-14 10:23 | 2016-08-12 09:59 |
Reporter | John Biddiscombe | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | moved | |
Product Version | 3.14.1 | |
Target Version | | Fixed in Version | | |
Summary | 0013173: Painter can report wrong bounds on first check |
Description | When the Renderer first calls ComputeVisiblePropBounds, the poly data painter mapper calls ComputeBounds on its painter, but this happens the first time before setInput has been called on the painter.
This patch fixes it. |
Tags | No tags attached. |
Project | TBD |
Topic Name | |
Type | incorrect functionality |
Attached Files | 0001-Fix-invalid-bounds-on-painter-initial-render.patch [^] (1,103 bytes) 2012-05-14 10:23 [Show Content] [Hide Content]From f0943ce393dbe7b888706d9f4f84b3fc2ae4c6b7 Mon Sep 17 00:00:00 2001
Date: Mon, 14 May 2012 16:19:24 +0200
Subject: [PATCH] Fix invalid bounds on painter initial render.
On First Render ComputeBounds can be called on a painter before input has been set.
Add a SetInput Call to the painter before updates to ensure it is able to
compute the correct bounds.
Change-Id: Iabccc4b618900d2491bfe5d1caa5879afd15cb10
Rendering/vtkPainterPolyDataMapper.cxx | 1 +
1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/Rendering/vtkPainterPolyDataMapper.cxx b/Rendering/vtkPainterPolyDataMapper.cxx
index 38bcba7..835e500 100644
--- a/Rendering/vtkPainterPolyDataMapper.cxx
+++ b/Rendering/vtkPainterPolyDataMapper.cxx
@@ -384,6 +384,7 @@ void vtkPainterPolyDataMapper::ComputeBounds()
if (this->PainterUpdateTime < this->GetMTime())
this->UpdatePainterInformation();
+ painter->SetInput(this->GetInput());
this->PainterUpdateTime.Modified();
painter->UpdateBounds(this->Bounds);
1.7.3.1.msysgit.0
