0013189 | ParaView | (No Category) | public | 2012-05-18 10:04 | 2016-08-12 09:59 | ||||
Reporter | Paul Edwards | ||||||||
Product Version | 3.14.1 | ||||||||
Summary | 0013189: inconsistent cuts from cells with a non-planar quad face | ||||||||
Description | When a cell has a non-planar face it can give a different cut depending on the normal (see image). Either could be considered correct but I would consider it a bug that it is not consistent for the same cell. To reproduce use a "Programmable Source" that outputs vtkUnstructuredGrid with the following script: 8<--------------------------------------------- output = self.GetOutput() npts = 5 pts = vtk.vtkPoints() pts.InsertNextPoint(-1.0, -1.0, -1.0) pts.InsertNextPoint( 1.0, -1.0, -0.5) pts.InsertNextPoint( 1.0, 1.0, -1.0) pts.InsertNextPoint(-1.0, 1.0, -0.5) pts.InsertNextPoint( 0.0, 0.0, 1.0) output.SetPoints(pts) output.Allocate(1,1) ids = vtk.vtkIdList() for i in range(npts): ids.InsertId(i,i) output.InsertNextCell(vtk.VTK_PYRAMID, ids) --------------------------------------------->8 Now apply "Slice" for Origin (0,0,-0.75) and try Normal of (0,0,-1) and (0,0,1). The output will be different depending on the direction. | ||||||||
Project | TBD | ||||||||
Attached Files | pyramid-cuts.png [^] (97,847 bytes) 2012-05-18 10:04
(0038215) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-05-18 10:04 | Paul Edwards | New Issue | |
2012-05-18 10:04 | Paul Edwards | File Added: pyramid-cuts.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038215 | |
