| 0013216 | ParaView | (No Category) | public | 2012-06-01 16:05 | 2016-08-12 09:59 | ||||
| Reporter | Andy Bauer | ||||||||
| Priority | low | Severity | minor | Reproducibility | have not tried | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | git-master | ||||||||
| Target Version | 4.0 | Fixed in Version | |||||||
| Summary | 0013216: create a filter to remove field data arrays | ||||||||
| Description | For writers in general and coprocessing specifically it would be useful to have a filter to remove arrays that don't need to be written out. | ||||||||
| Project | CoProcessing | ||||||||
| Topic Name | 13216-fix-pass-arrays-modifed-state | ||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028772) Utkarsh Ayachit (administrator) 2012-07-13 10:41 |
merged into master (if applicable) |
(0028778) Andy Bauer (developer) 2012-07-13 11:04 |
The filter seems to be working properly except that the custom panel has problems when the active source is changed to a previous filter and then back to the vtkPassArrays filter. The problem is that the Apply and Reset buttons should be disabled at that point but they aren't. |
(0028779) Andy Bauer (developer) 2012-07-13 11:13 |
You can use the passarrays.py script to help show the problem. To recreate the problem: 1) run the passarrays.py script 2) Hit apply 3) Click on the PointDatatoCellData1 filter 4) Click on the PassArrays1 filter Now the Apply and Reset buttons are active but should be disabled. |
(0029013) Kyle Lutz (viewer) 2012-08-16 14:42 |
Merge topic '13216-fix-pass-arrays-modifed-state' into next 0d02bec Fix bug with the Pass Arrays properties panel modifed state |
(0029019) Utkarsh Ayachit (administrator) 2012-08-17 14:27 |
merged in master, if applicable |
(0029124) Andy Bauer (developer) 2012-09-04 11:30 |
Something is still wrong with this. Now it doesn't update (i.e. call RequestData in the filter) when Apply is pressed. To recreate the problem: 1) create a wavelet and hit apply 2) create pass arrays filter and hit apply 3) look at the Information tab to see that the grid hasn't been created. |
(0038222) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2012-06-01 16:05 | Andy Bauer | New Issue | |
| 2012-06-01 16:05 | Andy Bauer | Assigned To | => Andy Bauer |
| 2012-06-01 16:06 | Andy Bauer | Status | backlog => todo |
| 2012-06-01 16:07 | Andy Bauer | Status | todo => active development |
| 2012-07-11 13:15 | Andy Bauer | Topic Name | => 13216_expose_vtkPassArrays |
| 2012-07-11 13:15 | Andy Bauer | Status | active development => gatekeeper review |
| 2012-07-11 13:15 | Andy Bauer | Resolution | open => fixed |
| 2012-07-13 10:41 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-07-13 10:41 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-07-13 10:41 | Utkarsh Ayachit | Note Added: 0028772 | |
| 2012-07-13 11:02 | Andy Bauer | Assigned To | Andy Bauer => Kyle Lutz |
| 2012-07-13 11:04 | Andy Bauer | Note Added: 0028778 | |
| 2012-07-13 11:04 | Andy Bauer | Status | customer review => todo |
| 2012-07-13 11:11 | Andy Bauer | File Added: passarrays.py | |
| 2012-07-13 11:13 | Andy Bauer | Note Added: 0028779 | |
| 2012-08-16 13:18 | Kyle Lutz | Status | todo => active development |
| 2012-08-16 14:42 | Kyle Lutz | Note Added: 0029013 | |
| 2012-08-16 14:42 | Kyle Lutz | Status | active development => gatekeeper review |
| 2012-08-16 14:43 | Kyle Lutz | Topic Name | 13216_expose_vtkPassArrays => 13216-fix-pass-arrays-modifed-state |
| 2012-08-17 14:27 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-08-17 14:27 | Utkarsh Ayachit | Note Added: 0029019 | |
| 2012-09-04 11:30 | Andy Bauer | Note Added: 0029124 | |
| 2012-09-04 11:30 | Andy Bauer | Status | customer review => todo |
| 2012-10-18 14:05 | Utkarsh Ayachit | Target Version | => 4.0 |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2013-01-14 12:45 | Kyle Lutz | Status | todo => active development |
| 2013-10-31 11:19 | Utkarsh Ayachit | Assigned To | Kyle Lutz => |
| 2013-10-31 11:19 | Utkarsh Ayachit | Status | active development => todo |
| 2013-10-31 11:19 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2013-10-31 11:19 | Utkarsh Ayachit | Status | todo => backlog |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038222 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Fixed in Version | 3.98.0 => |
| 2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
| Issue History |
