0013219 | ParaView | (No Category) | public | 2012-06-05 09:58 | 2013-01-22 16:37 | ||||
Reporter | George Zagaris | ||||||||
Assigned To | George Zagaris | ||||||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013219: Visibility of AMR data is wrong with AMR datasets that have ghost cells | ||||||||
Description | The visibility is not calculated correctly for grids that have ghost cells. Because, ghost cells partially overlap low-res cells, the low-res cells are marked as not visible and gaps between levels are introduced in the visualization. This issue can be reproduced with Chombo data from ParaViewData/Data/VisItBridge/plot0.00000.2d.hdf5 | ||||||||
Project | TBD | ||||||||
Topic Name | removing-amr-ghost-layers | ||||||||
(0028674) George Zagaris (developer) 2012-06-05 10:14 |
Implemented functionality for detecting and removing ghost layers that are partially overlap low-res cells. The corresponding topic brings in the related VTK and VisItBridge updates. |
(0028686) Utkarsh Ayachit (administrator) 2012-06-11 19:57 |
merged into master |
(0030221) Alan Scott (manager) 2013-01-22 16:37 |
Tested remote server, Linux, master. |
2012-06-05 09:58 | George Zagaris | New Issue | |
2012-06-05 09:58 | George Zagaris | Assigned To | => George Zagaris |
2012-06-05 10:14 | George Zagaris | Topic Name | => removing-amr-ghost-layers |
2012-06-05 10:14 | George Zagaris | Note Added: 0028674 | |
2012-06-05 10:14 | George Zagaris | Status | backlog => gatekeeper review |
2012-06-05 10:14 | George Zagaris | Fixed in Version | => git-master |
2012-06-05 10:14 | George Zagaris | Resolution | open => fixed |
2012-06-11 19:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-06-11 19:57 | Utkarsh Ayachit | Note Added: 0028686 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-22 16:37 | Alan Scott | Note Added: 0030221 | |
2013-01-22 16:37 | Alan Scott | Status | customer review => closed |
