0013248 | ParaView | (No Category) | public | 2012-06-18 08:27 | 2016-08-12 09:59 | ||||
Reporter | Philippe Pébay | ||||||||
Target Version | git-next | Fixed in Version | |||||||
Summary | 0013248: Default behaviour for volume rendering between image and unstructured data | ||||||||
Description | PV does not support client-side volume rendering. As a result, when running on parallel, the behaviour of volume rendering is not consistent between image and unstructured data: if the data set is small enough not make the server-side threshold, then the client only renders the outline. From a user's perspective this is bad for at least 2 reasons: 1. The inconsistency between image and unstructured data cannot be easily figure out, and is counter-intuitive, as one would expect that the easiest case (regular grid) is handled when the hard one is not--but the opposite occurs. 2. The way to fix this behaviour requires relatively advanced knowledge of PV, and is a bad fix because it forces server-side rendering even for small data sets when this is not warranted. Therefore I suggest that client-side VR be either never, or always (i.e., for both image and unstructured data) permitted. | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
(0038229) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-06-18 08:27 | Philippe Pébay | New Issue | |
2012-06-18 09:07 | Philippe Pébay | Type | incorrect functionality => usability |
2012-06-18 09:07 | Philippe Pébay | Reproducibility | have not tried => always |
2012-06-18 09:07 | Philippe Pébay | Target Version | => git-next |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038229 | |
