| 0013250 | ParaView | (No Category) | public | 2012-06-19 14:20 | 2012-10-29 17:04 | ||||
| Reporter | Sebastien Jourdain | ||||||||
| Assigned To | Sebastien Jourdain | ||||||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013250: Writer extension defined in GUI XML instead of WriterFactory hint | ||||||||
| Description | This should work as it was the way it was working before. The backward compatibility was broken when the Multi-Server was introduced. | ||||||||
| Project | ParaViS | ||||||||
| Topic Name | 13250-fix-writer-factory-to-also-use-gui-xml | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028706) Utkarsh Ayachit (administrator) 2012-06-20 10:37 |
merged in master if applicable. |
(0028868) Alan Scott (manager) 2012-07-19 15:37 |
Developer tag in the bug tracker. Closing. |
| Notes |
| Issue History | |||
| 2012-06-19 14:20 | Sebastien Jourdain | New Issue | |
| 2012-06-19 14:20 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain |
| 2012-06-19 14:21 | Sebastien Jourdain | Status | backlog => todo |
| 2012-06-19 14:21 | Sebastien Jourdain | Status | todo => active development |
| 2012-06-19 14:23 | Sebastien Jourdain | Topic Name | => 13250-fix-writer-factory-to-also-use-gui-xml |
| 2012-06-19 14:23 | Sebastien Jourdain | Status | active development => gatekeeper review |
| 2012-06-19 14:23 | Sebastien Jourdain | Resolution | open => fixed |
| 2012-06-20 10:36 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-06-20 10:37 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-06-20 10:37 | Utkarsh Ayachit | Note Added: 0028706 | |
| 2012-07-19 15:37 | Alan Scott | Note Added: 0028868 | |
| 2012-07-19 15:37 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| Issue History |
