0013304 | ParaView | (No Category) | public | 2012-07-16 10:06 | 2012-11-01 15:04 | ||||
Reporter | Sebastien Jourdain | ||||||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013304: Add data annotation for time label information | ||||||||
Description | Allow source to override the default "time:" label in the Qt GUI when the "time" is not the time but mostly another dimension. | ||||||||
Project | TBD | ||||||||
Topic Name | 13304-time-label-annotation | ||||||||
Attached Files | ![]() ![]() ![]() ![]() | ||||||||
(0028902) Utkarsh Ayachit (administrator) 2012-07-24 10:48 |
merged into master, if applicable. |
(0028934) Sebastien Jourdain (manager) 2012-07-25 14:29 edited on: 2012-07-25 15:03 |
To test: - Load the NonOrthogonalSource plugin - Create the Source -> ShearedCube - Use Time Label (One of the checkbox) - Change the "Time Label" to be something else than "Time" - Apply The label in the toolbar for Time: should have changed to what you setup. The label inside the Information tab giving you the current time should change as well. Moreover, if more than 1 source tries to annotate the Time Label, the default value "Time" should be used unless they all share the same label. |
(0028936) Alan Scott (manager) 2012-07-25 16:52 |
Excellent. Tested local server, Linux, master. |
(0028965) Sebastien Jourdain (manager) 2012-08-01 11:30 |
Update more UI components with time label - Time/StartTime/EndTime labels inside AnimationView are updated now - Time group title in ProxyInformation is updated now as well |
(0028986) Utkarsh Ayachit (administrator) 2012-08-10 14:36 |
merged into master |
(0029645) Alan Scott (manager) 2012-11-01 15:04 |
Tested remote server, master, Linux. |
2012-07-16 10:06 | Sebastien Jourdain | New Issue | |
2012-07-16 10:35 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain |
2012-07-16 10:35 | Sebastien Jourdain | Status | backlog => todo |
2012-07-16 10:36 | Sebastien Jourdain | Status | todo => active development |
2012-07-18 09:29 | Sebastien Jourdain | Topic Name | => 13304-time-label-annotation |
2012-07-18 09:29 | Sebastien Jourdain | Status | active development => gatekeeper review |
2012-07-18 09:29 | Sebastien Jourdain | Resolution | open => fixed |
2012-07-24 10:47 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-07-24 10:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-07-24 10:48 | Utkarsh Ayachit | Note Added: 0028902 | |
2012-07-25 14:29 | Sebastien Jourdain | Note Added: 0028934 | |
2012-07-25 15:02 | Sebastien Jourdain | File Added: TimeLabel1.png | |
2012-07-25 15:02 | Sebastien Jourdain | File Added: TimeLabel2.png | |
2012-07-25 15:03 | Sebastien Jourdain | Note Edited: 0028934 | |
2012-07-25 16:52 | Alan Scott | Note Added: 0028936 | |
2012-07-25 16:52 | Alan Scott | Status | customer review => closed |
2012-08-01 10:16 | Sebastien Jourdain | Status | closed => backlog |
2012-08-01 10:16 | Sebastien Jourdain | Resolution | fixed => reopened |
2012-08-01 10:16 | Sebastien Jourdain | Status | backlog => todo |
2012-08-01 10:17 | Sebastien Jourdain | Status | todo => active development |
2012-08-01 11:30 | Sebastien Jourdain | Note Added: 0028965 | |
2012-08-01 11:30 | Sebastien Jourdain | Status | active development => gatekeeper review |
2012-08-01 11:30 | Sebastien Jourdain | Resolution | reopened => fixed |
2012-08-10 14:36 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-08-10 14:36 | Utkarsh Ayachit | Note Added: 0028986 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2012-11-01 15:04 | Alan Scott | Note Added: 0029645 | |
2012-11-01 15:04 | Alan Scott | Status | customer review => closed |
