| 0013317 | ParaView | (No Category) | public | 2012-07-20 05:52 | 2013-01-22 16:50 | ||||
| Reporter | Ian Curington | ||||||||
| Assigned To | Kyle Lutz | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 3.14.1 | ||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013317: State restore using Xdmf loss of Apply resolved parameter status | ||||||||
| Description | Restoring state file with Xdmf loader, with interactive pipeline selection shows Apply button active, pipeline name bold, although nothing changed. Selecting Apply on larger data in this case can cause loss of data in pipeline. Problem Environment - ParaView 3.14.1 Win7 x64 vc2010, Python 2.7, Qt 4.7.4 compiled from sources. 1. load attached test3.xmf (very small single triangle) 2. push apply 3. see triangle on screen 4. get sources: cone 5. push apply. 6. see triangle and cone together 7. save state file 8. close and restart paraview (or at least clean pipeline) 9. reload state file 10. repeatedly click to select each of the two objects in pipeline browser. 11. At some point, test3.xmf becomes bold, and Apply button is active. ... 12. If loading some larger xdmf data, there is further intermittent effect, where after such secondary apply, data vanishes, all downstream pipeline is frozen. 13. Seems to only affect xdmf. STL, VTK, INP, or using multiple built-in sources (such as multiple cones). are all OK. 14. Only needs a single Xdmf input file, plus anything else in the pipeline, either independent or connected. 15. If automatic apply mode selected, problem is worse, session unusable. Occurs on most Xdmf files, with or without heavy (hdf5) - see attached tiny test case for verification. | ||||||||
| Tags | New Panels | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0028887) MJW (reporter) 2012-07-20 10:31 |
Thanks for reporting this Ian. This problem is preventing us from using the software for consultancy applications with XDMF files, as we are unable to re-edit workspaces that have been saved using a state file. |
(0029130) MJW (reporter) 2012-09-05 14:01 |
UPDATE: this bug is not present in Version 3.12. We only have the problem in Version 3.14, so it seems to have been introduced with the GUI changes between V3.12 and V3.14. |
(0029200) Ian Curington (reporter) 2012-09-13 13:23 |
Further test results: - Exactly same pipeline works OK if built by hand in current session. - Bug appears only when pipeline is reloaded from state file. - Bug is verified on ParaView 3.14.1 Win7 x64 VC2010, Qt 4.7.4 source build - Bug is verified on ParaView 3.14.1 Win x64 Binary Kitware Download - Bug is verified on ParaView 3.14.1 Linux x64 source build - Bug is verified on older ParaView 3.14.0 (March 2012 build) source build. |
(0029201) Ian Curington (reporter) 2012-09-13 13:32 |
On ParaView Mail List, 13 August 2012, subject "some ui issues", burlen.loring@gmail.com commented: "I've noticed that the slice filter is having similar issue: apply activated by selecting in the pipeline browser. In my panels this was because pv is creating/destroying the panel as the object is selected/deselected in the browser so I had to be more careful during the initialization not to mark the object as modified, it's probably a similar issue." I wonder if this could be related, i.e. maybe Utilities/Xdmf2/vtk/vtkXdmfReader code is inadvertently marking object as modified? |
(0029209) Ian Curington (reporter) 2012-09-14 11:34 |
0013431 (recent fix) "Exodus Apply goes Green" seems related. |
(0029211) Ian Curington (reporter) 2012-09-14 12:53 |
current Git master pqProxySILModel.cxx fix by Kyle in 0013431 applied into 3.14.1 sources, appears to fix, requires more testing. |
(0029213) Kyle Lutz (viewer) 2012-09-14 14:57 |
The issue should be resolved by commit deab2d0 (now merged in ParaView-master). Please reopen if the issue still persists. |
(0029214) Ian Curington (reporter) 2012-09-14 15:18 |
Thank you very much! I will continue testing to verify fix. |
(0029259) Utkarsh Ayachit (administrator) 2012-09-21 14:05 |
merged into master, if applicable. |
(0030223) Alan Scott (manager) 2013-01-22 16:50 |
Marking closed, although it sounds like it may be subtle to reproduce. If it is still an issue, please reopen with additional information. Tested Linux, remote server, master. I really did beat on it for some time, as listed in step 10 below. |
| Notes |
| Issue History | |||
| 2012-07-20 05:52 | Ian Curington | New Issue | |
| 2012-07-20 05:52 | Ian Curington | File Added: test3.xmf | |
| 2012-07-20 10:31 | MJW | Note Added: 0028887 | |
| 2012-09-05 14:01 | MJW | Note Added: 0029130 | |
| 2012-09-13 13:23 | Ian Curington | Note Added: 0029200 | |
| 2012-09-13 13:32 | Ian Curington | Note Added: 0029201 | |
| 2012-09-14 11:34 | Ian Curington | Note Added: 0029209 | |
| 2012-09-14 12:53 | Ian Curington | Note Added: 0029211 | |
| 2012-09-14 14:57 | Kyle Lutz | Note Added: 0029213 | |
| 2012-09-14 14:57 | Kyle Lutz | Status | backlog => gatekeeper review |
| 2012-09-14 14:57 | Kyle Lutz | Resolution | open => fixed |
| 2012-09-14 14:57 | Kyle Lutz | Assigned To | => Kyle Lutz |
| 2012-09-14 14:57 | Kyle Lutz | Relationship added | related to 0013431 |
| 2012-09-14 15:18 | Ian Curington | Note Added: 0029214 | |
| 2012-09-17 16:05 | Utkarsh Ayachit | Tag Attached: New Panels | |
| 2012-09-21 14:05 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-09-21 14:05 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-09-21 14:05 | Utkarsh Ayachit | Note Added: 0029259 | |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2013-01-22 16:50 | Alan Scott | Note Added: 0030223 | |
| 2013-01-22 16:50 | Alan Scott | Status | customer review => closed |
| Issue History |
