| 0013334 | ParaView | (No Category) | public | 2012-07-31 21:07 | 2012-10-29 17:04 | ||||
| Reporter | Andy Bauer | ||||||||
| Assigned To | Andy Bauer | ||||||||
| Product Version | 3.14.1 | ||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013334: inconsistent output from contour filter for multiblock data sets with image data and unstructured grids | ||||||||
| Description | When contouring a multiblock data set where some of the blocks are vtkImageData and some of the blocks are vtkUnstructuredGrids, the output is inconsistent in that the output from the vtkUnstructuredGrid passes all of the fields while the output from the vtkImageData doesn't pass the contoured variable but does pass a Normals array. To reproduce: 1) create a wavelet source 2) create a clip filter to create an unstructured grid 3) use the group data set filter to group them into a multiblock data set 4) create an elevation filter 5) create a contour filter and contour by Elevation 6) look at the output and note that both Normals and Elevation point data arrays are listed as partial | ||||||||
| Project | CoProcessing | ||||||||
| Topic Name | 13334_multiblock_contour | ||||||||
| Type | usability | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029142) Utkarsh Ayachit (administrator) 2012-09-07 14:50 |
merged in master if applicable |
| Notes |
| Issue History | |||
| 2012-07-31 21:07 | Andy Bauer | New Issue | |
| 2012-08-14 15:50 | Andy Bauer | Assigned To | => Andy Bauer |
| 2012-09-05 13:30 | Andy Bauer | Status | backlog => todo |
| 2012-09-05 13:31 | Andy Bauer | Status | todo => active development |
| 2012-09-05 13:31 | Andy Bauer | Topic Name | => 13334_multiblock_contour |
| 2012-09-05 13:31 | Andy Bauer | Status | active development => gatekeeper review |
| 2012-09-05 13:31 | Andy Bauer | Resolution | open => fixed |
| 2012-09-05 13:31 | Andy Bauer | Fixed in Version | => git-next |
| 2012-09-07 14:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-09-07 14:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-09-07 14:50 | Utkarsh Ayachit | Note Added: 0029142 | |
| 2012-10-12 10:55 | Andy Bauer | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| Issue History |
