| 0013364 | ParaView | (No Category) | public | 2012-08-16 12:41 | 2012-10-29 17:04 | ||||
| Reporter | Kyle Lutz | ||||||||
| Assigned To | Kyle Lutz | ||||||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013364: Cut filter uses custom panel | ||||||||
| Description | Change the Cut filter to use the new properties panel. | ||||||||
| Project | TBD | ||||||||
| Topic Name | new-cut-panel | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029009) Kyle Lutz (viewer) 2012-08-16 12:41 |
Merge topic 'new-cut-panel' into next 9200843 Add new cut panel |
(0029010) Kyle Lutz (viewer) 2012-08-16 12:44 |
Previously the slice filter used a custom object panel. Now the slice filter uses the properties panel framework and a custom property widget was added for its "Slice Offset Values" property. Steps to verify: 1. Sources -> Wavelet 2. Filters -> Slice 3. The properties panel after this commit looks the same as the properties panel before this commit. |
(0029026) Utkarsh Ayachit (administrator) 2012-08-17 14:27 |
merged in master, if applicable |
| Notes |
| Issue History | |||
| 2012-08-16 12:41 | Kyle Lutz | New Issue | |
| 2012-08-16 12:41 | Kyle Lutz | Topic Name | => new-cut-panel |
| 2012-08-16 12:41 | Kyle Lutz | Note Added: 0029009 | |
| 2012-08-16 12:41 | Kyle Lutz | Status | backlog => gatekeeper review |
| 2012-08-16 12:41 | Kyle Lutz | Resolution | open => fixed |
| 2012-08-16 12:41 | Kyle Lutz | Assigned To | => Kyle Lutz |
| 2012-08-16 12:44 | Kyle Lutz | Note Added: 0029010 | |
| 2012-08-17 14:26 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-08-17 14:27 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-08-17 14:27 | Utkarsh Ayachit | Note Added: 0029026 | |
| 2012-08-27 13:35 | Kyle Lutz | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| Issue History |
