0013377VTK(No Category)public2012-08-20 14:452013-07-29 11:40
ReporterUtkarsh Ayachit
Assigned ToBrad King
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Summary0013377: SystemTools::EnableMSVCDebugHook using old environment variable.
DescriptionSystemTools::EnableMSVCDebugHook() is still using the old DART environment variable to determine if we are running dashboard tests.
Ideally, we'd add support for the new DASHBOARD_TEST_FROM_CTEST variable.
TagsNo tags attached.
ProjectKitware
Typeincorrect functionality
 Relationships
  Notes
(0029032)
David Cole (developer)
2012-08-20 14:48
Both variables are set by ctest, and always will be for backwards compatibility.
(0029033)
Brad King (developer)
2012-08-20 16:37
edited on: 2012-08-20 16:38
Try this patch:
diff --git a/Utilities/KWSys/vtksys/SystemTools.cxx b/Utilities/KWSys/vtksys/SystemTools.cxx
index 66850e9..4fd2c04 100644
--- a/Utilities/KWSys/vtksys/SystemTools.cxx
+++ b/Utilities/KWSys/vtksys/SystemTools.cxx
@@ -4841,7 +4841,8 @@ static int SystemToolsDebugReport(int, char* message, int*)
 void SystemTools::EnableMSVCDebugHook()
-  if (getenv("DART_TEST_FROM_DART"))
+  if (getenv("DART_TEST_FROM_DART") ||
+      getenv("DASHBOARD_TEST_FROM_CTEST"))
     _CrtSetReportHook(SystemToolsDebugReport);
(0031245)
Dave DeMarle (administrator)
2013-07-22 20:02
moving all "tabled" bugs into "backlog" category since "tabled" is no longer used.
(0031332)
2013-07-25 09:00
Patch from 0013377:0029033 applied to upstream KWSys:
 http://public.kitware.com/gitweb?p=KWSys.git;a=commitdiff;h=e39f85e0 [^]
(0031360)
2013-07-29 11:39
KWSys change from 0013377:0031332 imported to VTK:
 http://vtk.org/gitweb?p=VTK.git;a=commitdiff;h=196cc337 [^]
 Issue History
2012-08-20 14:45 Utkarsh Ayachit New Issue
2012-08-20 14:45 Utkarsh Ayachit Status backlog => tabled
2012-08-20 14:45 Utkarsh Ayachit Assigned To => Brad King
2012-08-20 14:48 David Cole Note Added: 0029032
2012-08-20 16:37 Brad King Note Added: 0029033
2012-08-20 16:38 Brad King Note Edited: 0029033
2013-07-22 20:02 Dave DeMarle Status tabled => backlog
2013-07-22 20:02 Dave DeMarle Note Added: 0031245
2013-07-25 09:00 Brad King Note Added: 0031332
2013-07-29 11:39 Brad King Status backlog => active development
2013-07-29 11:39 Brad King Note Added: 0031360
2013-07-29 11:40 Brad King Status active development => closed
2013-07-29 11:40 Brad King Resolution open => fixed
