0013379 | ParaView | (No Category) | public | 2012-08-20 17:38 | 2012-10-29 17:04 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013379: Properties panel has ugly buttons to implement collapsible groups | ||||||||
Description | The current implementation of the new properties panel has these ugly buttons labeled "Properties (PipelineName)" and "Display (DataType)" that act as toggles for collapsing those respective widgets. In the attached screen shot, the buttons in question are those two big blue buttons. This behavior is pretty terrible. First of all, it just looks ugly. Second, their behavior is unclear (or at least unnatural and inconsistent with other widgets). Buttons should not be used a toggles (see GUI Blooper "Using command buttons as toggles," http://books.google.com/books?id=cIY0JOAkLoYC&pg=PA66&lpg=PA66&dq=gui+blooper+toggle&source=bl&ots=uWwpXi3PqM&sig=pq3jazWL-yimwkcfV5UOrsSKVwk&hl=en&sa=X&ei=UXwiUJXVDsT5ygG4n4HQAQ&ved=0CFUQ6AEwAQ#v=onepage&q=gui%20blooper%20toggle&f=false [^]). Even if you do accept their toggle behavior, it is not clear that the action is to collapse a group. Third, the layout does not naturally suggest the grouping of the widgets. The buttons do not make good divisors. (Buttons are no better separators than they are toggles.) It is not as clear at a glance how the widgets group together as it should be. I think this ability to collapse the properties or display part of the inspector is dubious in the first place. Experience shows that you almost always need to access widgets from both, which is what made the separate Properties/Display tabs so frustrating. If you really want this behavior, then this should be implemented using the pqCollapsedGroup widget, which is already part of ParaView. It is designed to implement this functionality. Its behavior is clear and it looks much nicer. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13379_cleanup_properties_panel_ui | ||||||||
Attached Files | ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | ||||||||
Relationships | ||||||
(0029037) Utkarsh Ayachit (administrator) 2012-08-21 10:26 edited on: 2012-08-21 10:34 |
The collapsible group has a problem that it unnecessarily wastes horizontal space for the "group box" and padding around it, no matter how much we take the padding/margins down. The original plan with the implementation was to do something similar to what Qt Designer does for its "Widget Box" (QtDesigner-Widget Box.png).I've cleaned up the push button implementation to instead use a new pqExpanderButton class which is a raised frame with toggle state support. Screenshots included. What do you think? |
(0029038) Utkarsh Ayachit (administrator) 2012-08-21 10:30 |
commit 40d6575c8da63539e7d9277f058fec6b9f4b638f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Aug 21 10:28:13 2012 -0400 BUG 0013379. Cleanup toggle buttons in properties panel. Properties panel used ugle toggle buttons for expanding frames. Changed that use a new class pqExpanderButton which simulates the expanding buttons seen in the Widget box for Qt Designer. |
(0029039) Ken Moreland (manager) 2012-08-21 10:38 |
I can live with that. Can you post a screenshot on Mac? |
(0029041) Utkarsh Ayachit (administrator) 2012-08-21 12:31 |
Added a mac screenshot |
(0029042) Ken Moreland (manager) 2012-08-21 12:33 |
Yeah, that looks reasonable. |
(0029057) Utkarsh Ayachit (administrator) 2012-08-24 11:20 |
merged in master, if applicable. |
(0029229) Alan Scott (manager) 2012-09-19 22:18 |
I can live with the new implementation also. Tested local server, Linux, master. |
2012-08-20 17:38 | Ken Moreland | New Issue | |
2012-08-20 17:38 | Ken Moreland | File Added: PropertiesPanel.png | |
2012-08-20 17:39 | Ken Moreland | Relationship added | related to 0013344 |
2012-08-21 09:11 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-08-21 10:21 | Utkarsh Ayachit | File Added: alternative-all-open.png | |
2012-08-21 10:22 | Utkarsh Ayachit | File Added: alternative-display-closed.png | |
2012-08-21 10:23 | Utkarsh Ayachit | File Added: QtDesigner-Widget Box.png | |
2012-08-21 10:26 | Utkarsh Ayachit | Note Added: 0029037 | |
2012-08-21 10:30 | Utkarsh Ayachit | Topic Name | => 13379_cleanup_properties_panel_ui |
2012-08-21 10:30 | Utkarsh Ayachit | Note Added: 0029038 | |
2012-08-21 10:30 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-08-21 10:30 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-08-21 10:30 | Utkarsh Ayachit | Resolution | open => fixed |
2012-08-21 10:34 | Utkarsh Ayachit | Note Edited: 0029037 | |
2012-08-21 10:38 | Ken Moreland | Note Added: 0029039 | |
2012-08-21 12:30 | Utkarsh Ayachit | File Added: Screen Shot 2012-08-21 at 12.29.45 PM.png | |
2012-08-21 12:30 | Utkarsh Ayachit | File Deleted: Screen Shot 2012-08-21 at 12.29.45 PM.png | |
2012-08-21 12:31 | Utkarsh Ayachit | File Added: mac.newpanel.png | |
2012-08-21 12:31 | Utkarsh Ayachit | Note Added: 0029041 | |
2012-08-21 12:32 | Utkarsh Ayachit | File Added: mac.collapsed.newpanel.png | |
2012-08-21 12:33 | Ken Moreland | Note Added: 0029042 | |
2012-08-24 11:19 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-08-24 11:20 | Utkarsh Ayachit | Note Added: 0029057 | |
2012-08-24 11:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-19 22:18 | Alan Scott | Note Added: 0029229 | |
2012-09-19 22:18 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
