0013386 | ParaView | (No Category) | public | 2012-08-22 21:04 | 2012-10-29 17:04 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013386: Failure reading CTH files - Compute Derived Variables | ||||||||
Description | I have a CTH dataset that is failing on read. Windows (Linux also fails), local server, master. Open dataset. All vars on. Apply. Error print is as follows: ERROR: In ..\..\..\..\..\src\ParaView3\VTK\Common\DataModel\vtkDataSet.cxx, line 437 vtkRectilinearGrid (189FF048): Cell array Derived Density - 1 with 1 components, has only 0 tuples but there are 74884 cells The error is here: file: vtkDataSet.cxx, line 437. The cause of the error message is as follows: array name == Derived Density - 1 number of tuples == 0 number of cells = 74884 We are failing on an if test making sure that the number of tuples == number of cells. Workaround - in the reader, before clicking "Apply", deselect "Compute Derived Variables". This is a show stopper for 4.0. I will give Utkarsh the dataset. It is named flat_2d-crash-snl-do-not-release.tar.gz | ||||||||
Project | Sandia | ||||||||
Topic Name | 13386_fix_cth_derived_quantities | ||||||||
(0029048) Alan Scott (manager) 2012-08-22 21:05 |
Changing to todo. |
(0029133) Utkarsh Ayachit (administrator) 2012-09-05 18:23 |
commit 5c0213b0d59942514253ec02f1b6d466c3544c13 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Sep 5 18:17:42 2012 -0400 BUG 0013386. Fixed computation of derived values. 1. vtkSpyPlotBlock was using a incorrect SavedRealDims size of 6. We just need 3 elements for a dimension. Fixed that. That cleans up the incorrect initialization of SavedRealDims too. 2. vtkSpyPlotBlock::FixInformation() was increamenting "j" for 1 extra time when this->Dimensions[] was 1. Fixed that. This would have caused invalid writes for 2D datasets no in the XY plane. 3. SavedRealDims is set to valid values only when ghost cells were present in the data and we need to "fix" them. Hence fixed GetCellVolume() and ComputeDerivedVariables() calls to use SavedRealDims only when valid. This was causing the bug reported. Since some grids didn't have the extra ghost cells that needed to be fixed, the SavedRealDims was not set for those grids and we ended up with invalid dimensions being used when computing the derived quantities. |
(0029143) Utkarsh Ayachit (administrator) 2012-09-07 14:50 |
merged in master if applicable |
(0029225) Alan Scott (manager) 2012-09-19 19:46 |
Excellent. Tested remote server, Linux, master. |
2012-08-22 21:04 | Alan Scott | New Issue | |
2012-08-22 21:05 | Alan Scott | Note Added: 0029048 | |
2012-08-22 21:05 | Alan Scott | Assigned To | => Alan Scott |
2012-08-22 21:05 | Alan Scott | Status | backlog => todo |
2012-09-05 18:23 | Utkarsh Ayachit | Topic Name | => 13386_fix_cth_derived_quantities |
2012-09-05 18:23 | Utkarsh Ayachit | Note Added: 0029133 | |
2012-09-05 18:23 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-09-05 18:23 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-09-05 18:23 | Utkarsh Ayachit | Resolution | open => fixed |
2012-09-05 18:23 | Utkarsh Ayachit | Assigned To | Alan Scott => Utkarsh Ayachit |
2012-09-07 14:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-09-07 14:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-07 14:50 | Utkarsh Ayachit | Note Added: 0029143 | |
2012-09-19 19:46 | Alan Scott | Note Added: 0029225 | |
2012-09-19 19:46 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
