0013393 | ParaView | (No Category) | public | 2012-08-24 15:17 | 2015-01-11 08:37 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013393: Build broken for clusters with visitBridge | ||||||||
Description | Compile Master is broken when the visit reader is turned on. Error message is as follows: 90%] Built target vtkRenderingLODCS Linking CXX shared library ../../../lib/libvtkIOVisItBridge-pv3.14.so CMakeFiles/vtkIOVisItBridge.dir/GMV/avtGMVFileFormat.C.o: In function `gmvAddGeneralCell(vtkUnstructuredGrid*, vtkPoints*, gmvPolyhedralSplit*, std::vector<float, std::allocator<float> >&, int&)': avtGMVFileFormat.C:(.text+0x20ec): undefined reference to `gluNewTess' avtGMVFileFormat.C:(.text+0x2108): undefined reference to `gluTessCallback' avtGMVFileFormat.C:(.text+0x2121): undefined reference to `gluTessCallback' avtGMVFileFormat.C:(.text+0x213a): undefined reference to `gluTessCallback' avtGMVFileFormat.C:(.text+0x2153): undefined reference to `gluTessCallback' avtGMVFileFormat.C:(.text+0x2170): undefined reference to `gluTessNormal' avtGMVFileFormat.C:(.text+0x218a): undefined reference to `gluTessProperty' avtGMVFileFormat.C:(.text+0x21a0): undefined reference to `gluTessProperty' avtGMVFileFormat.C:(.text+0x21c8): undefined reference to `gluTessNormal' avtGMVFileFormat.C:(.text+0x21f0): undefined reference to `gluTessBeginPolygon' avtGMVFileFormat.C:(.text+0x21fd): undefined reference to `gluTessBeginContour' avtGMVFileFormat.C:(.text+0x2251): undefined reference to `gluTessVertex' avtGMVFileFormat.C:(.text+0x22c5): undefined reference to `gluTessEndContour' avtGMVFileFormat.C:(.text+0x22d2): undefined reference to `gluTessEndPolygon' avtGMVFileFormat.C:(.text+0x24ac): undefined reference to `gluDeleteTess' avtGMVFileFormat.C:(.text+0x28f7): undefined reference to `gluDeleteTess' collect2: ld returned 1 exit status | ||||||||
Project | Sandia | ||||||||
Topic Name | 13393_fix_gmv_reader_build_issue | ||||||||
Type | crash | ||||||||
(0029069) Utkarsh Ayachit (administrator) 2012-08-25 15:32 |
The problem is that VisItGMVReader depends on GLU. I am guessing OPENGL_glu_LIBRARY is empty on your system. The correct fix is disable GMV reader is GLU is not found. Working on it. |
(0029070) Utkarsh Ayachit (administrator) 2012-08-25 16:00 |
commit adb5963160434d06fa8ff2353b7ab0b02eac0940 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Aug 25 15:59:03 2012 -0400 BUG 0013393. Update VisItBridge to bring in compilation fix. Disabling GMV reader when OpenGLU is not available (and enable it otherwise). commit c01fbf6fb2460ea388f4654f4c112bbd6c736d3f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Aug 25 15:56:43 2012 -0400 BUG 0013393. Enable GMV reader only when OpenGLU is available. Enable GMV reader only when GLU is available. Also the option to optionally turn ON GMV reader didn't seem to work. Despite the fact the the GMV reader was turned on, it wasn't being built causing dashboard failures. This patch overcomes the issue by not making GMV user-optional, instead simply disabling it automatically when GLU was not available. |
(0029112) Utkarsh Ayachit (administrator) 2012-09-03 13:30 |
merged into master, if applicable. |
(0029355) Alan Scott (manager) 2012-10-10 18:29 |
Tested local linux and cluster build. master. |
2012-08-24 15:17 | Alan Scott | New Issue | |
2012-08-24 16:51 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-08-25 15:32 | Utkarsh Ayachit | Note Added: 0029069 | |
2012-08-25 16:00 | Utkarsh Ayachit | Note Added: 0029070 | |
2012-08-25 16:00 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-08-25 16:00 | Utkarsh Ayachit | Resolution | open => fixed |
2012-08-25 16:01 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-09-03 13:27 | Utkarsh Ayachit | Topic Name | => 13393_fix_gmv_reader_build_issue |
2012-09-03 13:30 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-03 13:30 | Utkarsh Ayachit | Note Added: 0029112 | |
2012-10-06 07:03 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-10 18:29 | Alan Scott | Note Added: 0029355 | |
2012-10-10 18:29 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2015-01-11 08:37 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master adb59631 |
