| 0013405 | ParaView | (No Category) | public | 2012-08-28 11:02 | 2012-10-29 17:05 | ||||
| Reporter | Ken Moreland | ||||||||
| Product Version | 3.14.1 | ||||||||
| Target Version | 3.98.0 | Fixed in Version | 3.98.0 | ||||||
| Summary | 0013405: Start/End time not set to TIME_RANGE (SLAC reader) | ||||||||
| Description | When a pipeline source reports a TIME_RANGE key without a TIME_STEPS key, ParaView should take the time range and set the start and end times to that range. That does not seem to be happening. At least, that does not seem to be happening for vtkSLACReader. To see the problem in effect, load the mesh and mode file located in VTKLargeData/Data/SLAC/ll-9cell-f523. (I find it easiest to load these files using the special open dialog in the SLACTools plugin.) When loaded, this reader should be reporting a time range starting at 0 and ending at 4.06994e-10. Instead, the start and end time both remain at 1. | ||||||||
| Project | TBD | ||||||||
| Topic Name | 13405_slac_reader_timerange_issue | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029127) Utkarsh Ayachit (administrator) 2012-09-04 16:35 |
commit 419f6df72b22ea9c82bb6e19e6b0f8b9a7ceac1f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Sep 4 16:33:37 2012 -0400 BUG 0013405. TimeRange not being updated correctly. pqSLACDataLoadManager was not calling UpdatePipelineInformation() after it changed properties that lead to new timerange information. As a consequence, the GUI was not detect the change in time range. Fixed that. This fixes BUG 0013405. |
(0029146) Utkarsh Ayachit (administrator) 2012-09-07 14:50 |
merged in master if applicable |
| Notes |
| Issue History | |||
| 2012-08-28 11:02 | Ken Moreland | New Issue | |
| 2012-08-28 11:02 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2012-09-04 16:35 | Utkarsh Ayachit | Topic Name | => 13405_slac_reader_timerange_issue |
| 2012-09-04 16:35 | Utkarsh Ayachit | Note Added: 0029127 | |
| 2012-09-04 16:35 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2012-09-04 16:35 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2012-09-04 16:35 | Utkarsh Ayachit | Resolution | open => fixed |
| 2012-09-07 14:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-09-07 14:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-09-07 14:50 | Utkarsh Ayachit | Note Added: 0029146 | |
| 2012-09-07 23:25 | Ken Moreland | Status | customer review => closed |
| 2012-09-07 23:25 | Ken Moreland | Fixed in Version | git-master => 4.0 |
| 2012-10-29 17:05 | Utkarsh Ayachit | Fixed in Version | 4.0 => 3.98.0 |
| 2012-10-29 17:05 | Utkarsh Ayachit | Target Version | => 3.98.0 |
| Issue History |
