0013412 | ParaView | (No Category) | public | 2012-08-29 23:53 | 2015-01-11 08:36 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013412: Windows build error when using Ninja | ||||||||
Description | C:\Kitware\ParaView\ParaViewSuperbuild-ninja\paraview\src\paraview-build>ninja -v -j1 ninja: warning: multiple rules generate lib\protoc.lib. build will not be correct; continuing anyway ninja: error: 'Applications\ParaView\..\..\Documentation\paraview.qch', needed by 'Applications\ParaView\qrc_paraview_help.cxx', missing and no known rule to make it | ||||||||
Project | Kitware | ||||||||
Topic Name | 13412_fix_documentation_dependency | ||||||||
(0029095) Utkarsh Ayachit (administrator) 2012-08-31 10:21 |
commit b79c9a0ef14ba3be27dfa22777b79f56074282ec Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Aug 30 23:25:52 2012 -0400 BUG 0013412: Fixing dependency issues when building documentation. Resolving build problems with Ninja when bulding embedded documentation for ParaView. The issue was deeper than just a Ninja problem. Docmentation/CMakeLists.txt was generaing a paraview.qhp file and a resource file under Applications/ParaView was dependending on it. That's a tricky dependency since Applications/ParaView doesn't see the rule to generate paraview.qhp. We overcome the issue by adding a phony ParaViewOnlineHelp target that we made paraview depend on and than ensured that the qhp was available by the time Applications/ParaView's resource file looked for it. Fixing the issue by moving Documentation to Applications/ParaView. The documentation is indeed for the ParaView application hence makes sense its included in the application's sub-dir. We build a static library containing the documnetation resource that's initied by ParaViewMainWindow constructor. |
(0029117) Utkarsh Ayachit (administrator) 2012-09-03 13:30 |
merged into master, if applicable. |
(0030230) Alan Scott (manager) 2013-01-22 17:19 |
Trusting Utkarsh and the nightly builds. |
2012-08-29 23:53 | Utkarsh Ayachit | New Issue | |
2012-08-29 23:53 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-08-31 10:21 | Utkarsh Ayachit | Topic Name | => 13412_fix_documentation_dependency |
2012-08-31 10:21 | Utkarsh Ayachit | Note Added: 0029095 | |
2012-08-31 10:21 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-08-31 10:21 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-08-31 10:21 | Utkarsh Ayachit | Resolution | open => fixed |
2012-09-03 13:30 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-03 13:30 | Utkarsh Ayachit | Note Added: 0029117 | |
2012-10-06 07:03 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-22 17:19 | Alan Scott | Note Added: 0030230 | |
2013-01-22 17:19 | Alan Scott | Status | customer review => closed |
2015-01-11 08:36 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 3e5df0ff |
2015-01-11 08:36 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b79c9a0e |
