0013421ParaView(No Category)public2012-09-03 12:072015-01-11 08:34
ReporterKevin H. Hobbs
Assigned ToKyle Lutz
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version4.0Fixed in Version3.98.0
Summary0013421: Image Slice Rep XZ/YZ Slice Slider Range
DescriptionThere is a bug in the image slice representation in ParaView from git.
In slice directions other than XY the slice slider range is limited to the number of XY slices.
To see the bug use the wavelet source with extent:
-100 100
-100 100
-10 10
Change the representation to slice, the slice direction to XY, and the camera viewto the -Z direction.
Use the slider to view all the slices orthogonal to the Z axis.
Now change the slice direction to XZ (or YZ), and the camera view to the -Y (or -X) direction.
Use the slider to try and see all the slices orthogonal to the Y (or X) axis.
Observe that the slider range is limited to the first 20 slices.
Other slices can be seen by entering their number in the text entry box.
Enter 100 and see a slice through the middle that could not be reached using the slider.
TagsNo tags attached.
ProjectTBD
Topic Name13421-fix-image-slice-domain
Typeincorrect functionality
 Relationships
  Notes
(0029492)
Kyle Lutz (viewer)
2012-10-23 13:25
Merge topic '13421-fix-image-slice-domain' into next
d408b01 Add ability for pqIntRangeWidget to listen to a domain
(0029548)
2012-10-29 10:50
merged into master, if applicable.
(0030117)
Alan Scott (manager)
2013-01-11 15:02
Very well written bug. Nice job.
Tested master, Windows, local server.
 Issue History
2012-09-03 12:07 Kevin H. Hobbs New Issue
2012-10-18 14:11 Utkarsh Ayachit Target Version => 4.0
2012-10-23 11:59 Kyle Lutz Assigned To => Kyle Lutz
2012-10-23 11:59 Kyle Lutz Status backlog => todo
2012-10-23 11:59 Kyle Lutz Status todo => active development
2012-10-23 13:25 Kyle Lutz Topic Name => 13421-fix-image-slice-domain
2012-10-23 13:25 Kyle Lutz Note Added: 0029492
2012-10-23 13:25 Kyle Lutz Status active development => gatekeeper review
2012-10-23 13:25 Kyle Lutz Resolution open => fixed
2012-10-29 10:50 Utkarsh Ayachit Fixed in Version => git-master
2012-10-29 10:50 Utkarsh Ayachit Status gatekeeper review => customer review
2012-10-29 10:50 Utkarsh Ayachit Note Added: 0029548
2012-10-29 17:04 Utkarsh Ayachit Fixed in Version git-master => 3.98.0
2013-01-11 15:02 Alan Scott Note Added: 0030117
2013-01-11 15:02 Alan Scott Status customer review => closed
2015-01-11 08:34 Kyle Lutz Source_changeset_attached => ParaView master d408b01b
