| 0013422 | ParaView | (No Category) | public | 2012-09-04 09:19 | 2013-02-11 16:02 | ||||
| Reporter | Sebastien Jourdain | ||||||||
| Assigned To | Sebastien Jourdain | ||||||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013422: Quad Slice View | ||||||||
| Description | - Create new custom composite representation for that view - Add support for slice representation - Add plane origin widget | ||||||||
| Project | Kitware | ||||||||
| Topic Name | quad_view_slice_view | ||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029256) Utkarsh Ayachit (administrator) 2012-09-21 14:05 |
merged into master, if applicable. |
(0029278) Sebastien Jourdain (manager) 2012-09-24 21:32 |
To test the new view: - Load the QuadView plugin - Close the 3D view and create a Quad View - Then load any data and switch the representation to Slices. - From now on, you can move the slices using the cross hair available in each sub-view - Additional control can be achieved by the view option accessible from the local view toolbar. You can run some test using the following command line: ctest -R QuadView |
| Notes |
| Issue History | |||
| 2012-09-04 09:19 | Sebastien Jourdain | New Issue | |
| 2012-09-04 09:19 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain |
| 2012-09-04 09:19 | Sebastien Jourdain | Status | backlog => todo |
| 2012-09-04 09:19 | Sebastien Jourdain | Status | todo => active development |
| 2012-09-14 17:01 | Sebastien Jourdain | Topic Name | => quad_view_slice_view |
| 2012-09-14 17:01 | Sebastien Jourdain | Status | active development => gatekeeper review |
| 2012-09-14 17:01 | Sebastien Jourdain | Resolution | open => fixed |
| 2012-09-21 14:05 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-09-21 14:05 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-09-21 14:05 | Utkarsh Ayachit | Note Added: 0029256 | |
| 2012-09-24 21:32 | Sebastien Jourdain | Note Added: 0029278 | |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2013-02-11 16:02 | Utkarsh Ayachit | Status | customer review => closed |
| Issue History |
