| 0013451 | ParaView | (No Category) | public | 2012-09-12 17:15 | 2015-01-11 08:34 | ||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013451: vtkFiltersParallelFlowPaths is not enabled in ParaView | ||||||||
| Description | vtkFiltersParallelFlowPaths is not enabled in ParaView. This is needed for stream tracer to work correctly in parallel. | ||||||||
| Project | Kitware | ||||||||
| Topic Name | 13451_fix_parallel_streamtracer | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029196) Utkarsh Ayachit (administrator) 2012-09-12 17:19 |
commit f54a67f8569afe0c1cd6b5b90a3646bfaf3eecab Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Sep 12 17:15:51 2012 -0400 BUG 0013451. Fixing modules needed by ParaView. Also fixing the logic to enable modules in VTK. Now we no longer force the cache variables. That approach was bad since once forced to on, those modules stayed enabled and user had to manually disable them. Instead, now we rely on COMPILE_DEPENDS to ensure that the necessary vtk modules are enabled. |
(0029207) Utkarsh Ayachit (administrator) 2012-09-14 11:09 |
merged in master, if applicable. |
(0029249) Alan Scott (manager) 2012-09-20 20:47 |
Internal hook for developers. Closing. |
| Notes |
| Issue History | |||
| 2012-09-12 17:15 | Utkarsh Ayachit | New Issue | |
| 2012-09-12 17:19 | Utkarsh Ayachit | Topic Name | => 13451_fix_parallel_streamtracer |
| 2012-09-12 17:19 | Utkarsh Ayachit | Note Added: 0029196 | |
| 2012-09-12 17:19 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2012-09-12 17:19 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2012-09-12 17:19 | Utkarsh Ayachit | Resolution | open => fixed |
| 2012-09-12 17:19 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2012-09-14 11:09 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-09-14 11:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-09-14 11:09 | Utkarsh Ayachit | Note Added: 0029207 | |
| 2012-09-20 20:47 | Alan Scott | Note Added: 0029249 | |
| 2012-09-20 20:47 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master c40338e0 |
| 2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master f54a67f8 |
| Issue History |
