0013507 | ParaView | (No Category) | public | 2012-10-10 16:33 | 2016-07-14 17:29 | ||||
Assigned To | Alan Scott | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0013507: Center node of Quad9 does not show up | ||||||||
Description | Using dataset 2d-quad9.g (ask Utkarsh), the following lack of feature shows up. * Surface with Edges. Notice the edges of the quad. * Points. Notice that there is a midpoint down the sides of the quad. Nothing shows up in the middle, however. * Select points through - rubber band select 4 cells in the upper left corner. Notice that the center point actually shows up. * Select a cell. Spreadsheet view. Display only selected. Notice that there are 9 points. The center point of the Quad should show up with points. This is a feature request. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0036481) Alan Scott (manager) 2016-07-14 17:29 |
Marking this one closed. There are some issues, but they are minor and if anyone notices them, they can open a new bug. Surface with edges works. Points is strange, but I don't think folks would use it much. Select Points Through works. Select a Cell. Works. Tested Windows, 5.1.0-RC1, local server. |
2012-10-10 16:33 | Alan Scott | New Issue | |
2016-07-14 17:29 | Alan Scott | Note Added: 0036481 | |
2016-07-14 17:29 | Alan Scott | Status | backlog => closed |
2016-07-14 17:29 | Alan Scott | Assigned To | => Alan Scott |
2016-07-14 17:29 | Alan Scott | Resolution | open => fixed |
