0013526 | ParaView | (No Category) | public | 2012-10-16 16:53 | 2013-01-08 18:22 | ||||
Target Version | 4.0 | Fixed in Version | |||||||
Summary | 0013526: build error when mpiexec not found | ||||||||
Description | There is a bug in ParaView when trying to build some clusters. If the build machine does not have access to mpiexec, the file VTK/Parallel/MPI/CMakeLists.txt tries to find said mpiexec file, and fails the build if not found. The easy way around this is to just put in a dummy path for MPIEXEC. However, this check should not error out if mpiexec is not found. Probably should be fixed before this check becomes mandatory. | ||||||||
Project | Sandia | ||||||||
(0029535) Utkarsh Ayachit (administrator) 2012-10-28 21:35 |
Alan, is this still an issue. I remember in the past it was checking for mpiexec even when MPI support was not enabled. That has been fixed. We do need MPIEXEC to be set when MPI support is enabled. |
(0030012) Alan Scott (manager) 2013-01-08 18:22 |
I think this is fixed, will create a new bug if not. |
2012-10-16 16:53 | Alan Scott | New Issue | |
2012-10-18 14:05 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-10-28 21:35 | Utkarsh Ayachit | Note Added: 0029535 | |
2012-10-28 21:35 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-28 21:35 | Utkarsh Ayachit | Resolution | open => no change required |
2012-10-28 21:35 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-10-28 21:35 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-08 18:22 | Alan Scott | Note Added: 0030012 | |
2013-01-08 18:22 | Alan Scott | Status | customer review => closed |
