0013596ParaView(No Category)public2012-10-31 20:282016-08-12 09:59
ReporterAlan Scott
Assigned ToDavid Thompson
StatusclosedResolutionmoved
PlatformOSOS Version
Product Versiongit-master
Summary0013596: Zoom to box does not zoom correctly.
DescriptionLinux, remote server, master.
sources/ sphere. Apply.
Zoom to box, upper left side of the sphere. Be sure to have some of the zoom inside and outside of the sphere.
<<Bug - the screen will only show the sphere>>
This was noticed by a user, thus should be fixed.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0034662)
Cory Quammen (developer)
2015-07-05 09:15
Alan,
I suspect this has to do with the inherent difficulty in using a 2D rectangle to specify a zoom region with perspective projection of a 3D scene. Try turning on the "Camera Parallel Projection" setting under the View section of the properties panel. Since this turns off perspective projection, the mapping from the rectangle to zoomed view is easier and seems to work better.
(0038269)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2012-10-31 20:28 Alan Scott New Issue
2012-12-11 09:53 Sebastien Jourdain Assigned To => David Thompson
2015-07-05 09:15 Cory Quammen Note Added: 0034662
2016-08-12 09:59 Kitware Robot Note Added: 0038269
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
