0013630 | ParaView | (No Category) | public | 2012-11-08 10:32 | 2012-12-06 21:35 | ||||
Reporter | Joe Borg | ||||||||
Assigned To | Kyle Lutz | ||||||||
Target Version | 3.98.0 | Fixed in Version | 3.98.0 | ||||||
Summary | 0013630: Extract Block now allowing multiple selection | ||||||||
Description | *This is an issue in 3.98* The screenshot attached shows the correct functionality in 3.14. This same, drag to select multiple, feature is not working in 3.98. On the surface, very trivial, but uses up a lot of time on large cases. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13630-extract-block-multiple-section | ||||||||
Attached Files | ![]() ![]() | ||||||||
(0029700) Utkarsh Ayachit (administrator) 2012-11-09 23:57 |
Kyle, can you check this one out please? This would go a long way to improve usability. Will be nice to have in the final release. |
(0029704) Kyle Lutz (viewer) 2012-11-12 12:20 |
Merge topic '13630-extract-block-multiple-section' into next 80acce2 Use pqTreeWidgetSelectionHelper for composite tree domains |
(0029705) Joe Borg (reporter) 2012-11-12 12:32 |
Thanks Kyle, I'll check this ASAP. |
(0029763) Kyle Lutz (viewer) 2012-11-20 12:16 |
Merged into ParaView-master (if applicable) |
(0029842) Alan Scott (manager) 2012-12-06 21:35 |
Tested local server, Linux, 3.98.0. |
2012-11-08 10:32 | Joe Borg | New Issue | |
2012-11-08 10:32 | Joe Borg | File Added: Screenshot.png | |
2012-11-09 23:56 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2012-11-09 23:57 | Utkarsh Ayachit | Note Added: 0029700 | |
2012-11-09 23:57 | Utkarsh Ayachit | Project | TBD => Sandia |
2012-11-09 23:57 | Utkarsh Ayachit | Priority | low => high |
2012-11-09 23:57 | Utkarsh Ayachit | Target Version | => 3.98.0 |
2012-11-12 10:59 | Kyle Lutz | Status | backlog => todo |
2012-11-12 12:20 | Kyle Lutz | Topic Name | => 13630-extract-block-multiple-section |
2012-11-12 12:20 | Kyle Lutz | Note Added: 0029704 | |
2012-11-12 12:20 | Kyle Lutz | Status | todo => gatekeeper review |
2012-11-12 12:20 | Kyle Lutz | Resolution | open => fixed |
2012-11-12 12:32 | Joe Borg | Note Added: 0029705 | |
2012-11-20 12:16 | Kyle Lutz | Status | gatekeeper review => customer review |
2012-11-20 12:16 | Kyle Lutz | Note Added: 0029763 | |
2012-12-06 21:35 | Alan Scott | Note Added: 0029842 | |
2012-12-06 21:35 | Alan Scott | Status | customer review => closed |
2012-12-06 21:35 | Alan Scott | Fixed in Version | => 3.98.0 |
