| 0013632 | ParaView | (No Category) | public | 2012-11-08 11:18 | 2012-11-08 11:41 | ||||
| Reporter | Joe Borg | ||||||||
| Assigned To | |||||||||
| Status | closed | Resolution | no change required | ||||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013632: Large geometry representation being set to surface instead of outline by default | ||||||||
| Description | In ParaView 3.14, if you load a large dataset, the representation would automatically be set to "Outline". If the dataset was smaller, or you use ExtractBlock to get the size down, ParaView selects "Surface" by default. In 3.98 however, everything is set to "Surface", so if you load a dataset with a huge flow field, it takes ages to load or crashes. | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029673) Joe Borg (reporter) 2012-11-08 11:41 |
I have found this setting. It's under "Edit" > "Settings..." > "Render View" > "Default Representation". |
| Notes |
| Issue History | |||
| 2012-11-08 11:18 | Joe Borg | New Issue | |
| 2012-11-08 11:41 | Joe Borg | Note Added: 0029673 | |
| 2012-11-08 11:41 | Joe Borg | Status | backlog => closed |
| 2012-11-08 11:41 | Joe Borg | Resolution | open => no change required |
| 2012-11-08 11:41 | Joe Borg | Fixed in Version | => 3.98.0 |
| Issue History |
