0013656 | ParaView | (No Category) | public | 2012-11-13 18:13 | 2016-08-12 09:59 | ||||
Reporter | Orion Poplawski | ||||||||
Summary | 0013656: Try to support using system installed protobuf | ||||||||
Description | For Fedora packages, need to use the system installed version of libraries. Attached is a hack to try to do that with 3.98.0. First step is to change: -vtk_module_third_party(protobuf +vtk_module_third_party(Protobuf in ParaView/ThirdParty/protobuf/CMakeLists.txt so that cmake finds FindProtobuf.cmake. Next I hacked out: +#vtk_target_export(protobuf) +#vtk_target_export(protobuf-lite) +#vtk_compile_tools_target_export(protoc_compiler) because they are not available in that configuration. Finally, Fedora 18 has protobuf 2.4.1 and the compiler is named "protoc" so I changed the name in ParaView/ParaViewCore/ServerImplementation/Core/CMakeLists.txt and removed protoc_compiler as a build dependency. Finally though I get the following link error: /usr/lib64/ccache/g++ -fPIC -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -g -Wl,--fatal-warnings -Wl,--no-undefined -lc -Wl,-z,relro -shared -Wl,-soname,libvtkPVServerImplementationCore-pv3.98.so.1 -o ../../../lib/libvtkPVServerImplementationCore-pv3.98.so.1 CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVCatalystSessionCore.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVProxyDefinitionIterator.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionBase.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionCore.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionCoreInterpreterHelper.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionServer.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIArraySelectionProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSICollaborationManager.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSICompoundSourceProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIDataArrayProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIDoubleVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIFileSeriesReaderProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIIdTypeVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIInputProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIIntVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIObject.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProxyDefinitionManager.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProxyProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSISILProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSISourceProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIStringVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSITimeLabelProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSITimeRangeProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSITimeStepsProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIWriterProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSMMessage.cxx.o ../../../lib/libvtkPVClientServerCoreCore-pv3.98.so.1 -lprotobuf ../../../lib/libvtkFiltersProgrammable-pv3.98.so.1 ../../../lib/libvtkPVPythonSupport-pv3.98.so.1 -lpython2.7 ../../../lib/libvtkPVVTKExtensionsCore-pv3.98.so.1 ../../../lib/libvtkPVCommon-pv3.98.so.1 ../../../lib/libvtkClientServer-pv3.98.so.1 ../../../lib/libvtkIOXML-pv3.98.so.1 ../../../lib/libvtkIOGeometry-pv3.98.so.1 ../../../lib/libvtkIOXMLParser-pv3.98.so.1 -lexpat ../../../lib/libvtkImagingCore-pv3.98.so.1 ../../../lib/libvtkInfovisCore-pv3.98.so.1 ../../../lib/libvtkFiltersExtraction-pv3.98.so.1 ../../../lib/libvtkFiltersGeneral-pv3.98.so.1 ../../../lib/libvtkFiltersCore-pv3.98.so.1 ../../../lib/libvtkCommonComputationalGeometry-pv3.98.so.1 ../../../lib/libvtkParallelCore-pv3.98.so.1 ../../../lib/libvtkIOLegacy-pv3.98.so.1 ../../../lib/libvtkIOCore-pv3.98.so.1 ../../../lib/libvtkCommonExecutionModel-pv3.98.so.1 ../../../lib/libvtkCommonDataModel-pv3.98.so.1 ../../../lib/libvtkCommonSystem-pv3.98.so.1 ../../../lib/libvtkCommonTransforms-pv3.98.so.1 ../../../lib/libvtkCommonMisc-pv3.98.so.1 ../../../lib/libvtkCommonMath-pv3.98.so.1 ../../../lib/libvtkCommonCore-pv3.98.so.1 ../../../lib/libvtksys-pv3.98.so.1 -ldl -lz -Wl,-rpath,/export/home/orion/fedora/paraview/ParaView/fedora/lib: CMakeFiles/vtkPVServerImplementationCore.dir/vtkSMMessage.cxx.o: In function `protobuf_AssignDescriptorsOnce': CMakeFiles/vtkPVServerImplementationCore.dir/vtkSMMessage.cxx.o:/usr/include/google/protobuf/stubs/once.h:115: more undefined references to `pthread_once' follow It's going to need to link against -lpthread but I don't know the best way to handle that. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
Attached Files | ![]() ![]() ![]() ![]() | ||||||||
(0031359) hasufell (reporter) 2013-07-29 10:59 |
Updated for paraview-4.0.1, with proper conditionals so both ON and OFF work as expected lpthread problem solved as well |
(0031363) Orion Poplawski (reporter) 2013-07-29 17:07 |
Updated patch works for me. |
(0033306) Orion Poplawski (reporter) 2014-09-03 14:10 |
With 4.2RC1 things will need to get updated as well. Looks like even less support for configuring it. |
(0033307) Orion Poplawski (reporter) 2014-09-03 18:41 |
Updated patch. Not sure if I need to re-add the thread stuff. There are problems interacting with the cmake FindProtobuf module (see also http://www.cmake.org/Bug/view.php?id=15128 [^]) due to its adding of items to PROTOBUF_LIBRARIES. Any suggestions there appreciated. |
(0033309) Orion Poplawski (reporter) 2014-09-04 12:33 |
These are the errors I get when the system FindProtobuf add -lpthread to PROTOBUF_LIBRARIES: CMake Error at CommandLineExecutables/CMakeLists.txt:71 (get_property): get_property could not find TARGET -lpthread. Perhaps it has not yet been created. CMake Error at CommandLineExecutables/CMakeLists.txt:76 (get_property): get_property could not find TARGET -lpthread. Perhaps it has not yet been created. Not sure if this is more of an issue with the ParaView cmake code making assumptions about various libraries, or something that should be fixed in cmake's FindProtobuf. |
(0033312) Orion Poplawski (reporter) 2014-09-05 12:06 |
paraview-cmake.patch is a patch suggested by the cmake folks to handle different kinds of entries in vtk_module_libraries. Appears to work for me. |
(0034391) Orion Poplawski (reporter) 2015-04-30 11:52 |
I believe this can be closed now as paraview does support the -DVTK_USE_SYSTEM_PROTOBUF:BOOL=ON option now. |
(0038279) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-11-13 18:13 | Orion Poplawski | New Issue | |
2012-11-13 18:13 | Orion Poplawski | File Added: paraview-Protobuf.patch | |
2013-07-29 10:59 | hasufell | File Added: paraview-4.0.1-Protobuf.patch | |
2013-07-29 10:59 | hasufell | Note Added: 0031359 | |
2013-07-29 17:07 | Orion Poplawski | Note Added: 0031363 | |
2014-09-03 14:10 | Orion Poplawski | Note Added: 0033306 | |
2014-09-03 18:39 | Orion Poplawski | File Added: paraview-4.2RC1-Protobuf.patch | |
2014-09-03 18:41 | Orion Poplawski | Note Added: 0033307 | |
2014-09-04 12:33 | Orion Poplawski | Note Added: 0033309 | |
2014-09-05 11:33 | Orion Poplawski | File Added: paraview-cmake.patch | |
2014-09-05 12:06 | Orion Poplawski | Note Added: 0033312 | |
2015-04-30 11:52 | Orion Poplawski | Note Added: 0034391 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038279 | |
