0013668 | ParaView | (No Category) | public | 2012-11-20 12:06 | 2014-08-29 10:59 | ||||
Reporter | Eelco van Vliet | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0013668: White boxes still appear around text and legends when running with pvbatch | ||||||||
Description | I continuation to issue 0012580, I checked if white boxes around text and legends still appear in version 3.98. It appear this is still the case. When I run pvbatch --use-offscreen-rendering /home/eelco/bin/pvbatchprocess.py --casedir rotDisk-neutralBuoyant/ --outputdir Images --inputdir "." --verbose --label "another_label:@(0.60,0.95)s12x0000AA" --statefile statefiles/pressure.pvsm --imagebase rotdisk-neutral_pressure --timeformat "Time:_%6.0f_ms" --timefileformat "%06d" --timeposition "0.4,0.02s12x000000" --timefactor "1000" --timefilefactor "10" On the python script attached, using the statesfiles/pressure.pvsm state file, the image rotdisk-neutral_pressure_t000000.png is produces which still contains white boxes. | ||||||||
Project | Catalyst | ||||||||
Attached Files | statefileandimage.tgz [^] (95,061 bytes) 2012-11-20 12:06 sample.pvsm [^] (103,355 bytes) 2014-07-30 13:20 foo.py [^] (131 bytes) 2014-07-30 13:20 | ||||||||
Relationships | |||||||||||
(0033148) Utkarsh Ayachit (administrator) 2014-07-30 13:21 |
seems to work now. I tested with the attached sample.pvsm and foo.py files instead. |
(0033157) Alan Scott (manager) 2014-07-30 15:14 |
Tested with Utkarsh's foo.py, below. Tested Linux, master, pvbatch. Used LAN build. |
2012-11-20 12:06 | Eelco van Vliet | New Issue | |
2012-11-20 12:06 | Eelco van Vliet | File Added: statefileandimage.tgz | |
2012-12-19 07:55 | Utkarsh Ayachit | Relationship added | related to 0012580 |
2013-03-14 10:19 | Utkarsh Ayachit | Relationship added | related to 0013927 |
2013-03-14 10:19 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-03-14 10:20 | Utkarsh Ayachit | Project | Kitware => Catalyst |
2013-03-14 10:20 | Utkarsh Ayachit | Priority | low => high |
2014-07-30 13:20 | Utkarsh Ayachit | File Added: sample.pvsm | |
2014-07-30 13:20 | Utkarsh Ayachit | File Added: foo.py | |
2014-07-30 13:21 | Utkarsh Ayachit | Note Added: 0033148 | |
2014-07-30 13:21 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-30 13:21 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-07-30 13:21 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2014-07-30 13:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-30 15:14 | Alan Scott | Note Added: 0033157 | |
2014-07-30 15:14 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
