0013687 | ParaView | (No Category) | public | 2012-11-28 05:42 | 2013-02-11 16:02 | ||||
Reporter | Takuya OSHIMA | ||||||||
Assigned To | Kyle Lutz | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013687: pqPipelineSource::visibilityChanged() not fired when a downstream filter changes visibility | ||||||||
Description | [ cf. http://www.paraview.org/pipermail/paraview/2012-November/026777.html [^] ] When a custom reader panel (a pqAutoGeneratedObjectPanel) connects to pqPipelineSource::visibilityChanged() signal of the corresponding reader proxy, the signal should be fired if a downstream filter that changes the visibility of the input (e.g. Slice) is added. This works as expected with PV 3.14.1 (+ earlier versions) and 3.98.0 RC3 when I --use-old-panels. However it does not with the new panels of the RC3. I attached a test plugin code to demonstrate the problem (a modified Examples/Plugins/GUIObjectPanel). Try: Build the plugin Start ParaView from a command terminal (with/without --use-old-panels) Load the plugin Sources - Cone, Apply Filters - Slice, Apply The expected behavior is a "Visibility changed" output on the terminal when a slice is added because it turns off the visiblity of the cone source. It works as expected when ParaView is started with --use-old-panels but not without the option. I checked on OS X 10.6.8, Qt 4.8.3, CMake 2.8.10. | ||||||||
Project | TBD | ||||||||
Attached Files | ![]() | ||||||||
(0029828) Kyle Lutz (viewer) 2012-12-03 14:11 |
I am unable to reproduce the issue with the current paraview master (same as the paraview 3.98.0 release). Do you get the "Visibility changed" output when you first create the cone and when you delete the cone? |
(0029977) Utkarsh Ayachit (administrator) 2013-01-04 14:46 |
merged into master, if applicable. |
2012-11-28 05:42 | Takuya OSHIMA | New Issue | |
2012-11-28 05:42 | Takuya OSHIMA | File Added: MyGUIObjectPanel.zip | |
2012-11-29 21:17 | Sebastien Jourdain | Assigned To | => Kyle Lutz |
2012-12-03 13:04 | Kyle Lutz | Status | backlog => todo |
2012-12-03 13:04 | Kyle Lutz | Status | todo => active development |
2012-12-03 14:11 | Kyle Lutz | Note Added: 0029828 | |
2013-01-04 09:45 | Kyle Lutz | Status | active development => gatekeeper review |
2013-01-04 09:45 | Kyle Lutz | Resolution | open => unable to reproduce |
2013-01-04 14:45 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-01-04 14:46 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-04 14:46 | Utkarsh Ayachit | Note Added: 0029977 | |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2013-02-11 16:02 | Utkarsh Ayachit | Status | customer review => closed |
