0013690 | ParaView | (No Category) | public | 2012-11-28 15:50 | 2013-02-17 14:13 | ||||
Reporter | Burlen | ||||||||
Assigned To | Burlen | ||||||||
Product Version | 3.98.0 | ||||||||
Summary | 0013690: MPI_Finalize out of order in pvbatch | ||||||||
Description | Hi All, pvbatch related tests have been failing for some time on Nautilus. http://open.cdash.org/viewTest.php?onlyfailed&buildid=2684614 [^] in pvbatch there are MPI calls made after finalize which cause deadlock issues on SGI MPT. The following snip-it shows the bug //---------------------------------------------------------------------------- bool vtkProcessModule::Finalize() { ... vtkProcessModule::GlobalController->Finalize(1); <-------mpi_finalize called here ... #ifdef PARAVIEW_USE_MPI if (vtkProcessModule::FinalizeMPI) { MPI_Barrier(MPI_COMM_WORLD); <-------------------------barrier after mpi_finalize MPI_Finalize(); <--------------------------------------second mpi_finalize } #endif ... } | ||||||||
Project | TBD | ||||||||
(0029811) Burlen (developer) 2012-11-29 20:07 |
also affects pvserver. after client disconnect , server hangs, and doesn't exit. |
(0030347) Burlen (developer) 2013-02-17 14:13 |
nautilus dashboards show that this issue has been fixed either directly or indirectly. Either way it can be closed. |
2012-11-28 15:50 | Burlen | New Issue | |
2012-11-29 20:07 | Burlen | Note Added: 0029811 | |
2013-02-17 14:13 | Burlen | Note Added: 0030347 | |
2013-02-17 14:13 | Burlen | Status | backlog => closed |
2013-02-17 14:13 | Burlen | Assigned To | => Burlen |
2013-02-17 14:13 | Burlen | Resolution | open => fixed |
