0013707 | VTK | (No Category) | public | 2012-12-06 08:57 | 2014-10-02 10:45 | ||||
Reporter | Giuseppe D'Angelo | ||||||||
Assigned To | Marcus D. Hanwell | ||||||||
Product Version | 5.8.0 | ||||||||
Summary | 0013707: vtkXOpenGLRenderWindow doesn't properly reset to the default cursor | ||||||||
Description | VTK 5.10.1, in vtkXOpenGLRenderWindow.cxx: 1985 if (shape == VTK_CURSOR_DEFAULT) 1986 { 1987 XUndefineCursor(this->DisplayId,this->WindowId); 1988 return; 1989 } I think this is wrong. This should reset the cursor to the one was set with SetCurrentCursor. Doing so will just switch to the parent's cursor instead. As a test, set a non-arrow cursor with SetCurrentCursor, then add a widget which changes the mouse cursor (f.i. a vtkScalarBarWidget). When moving the mouse outside the widget, it'll reset the cursor to a plain arrow. | ||||||||
Project | TBD | ||||||||
(0031058) Dave DeMarle (administrator) 2013-06-25 13:48 |
Giuseppe can you submit the patch via gerrit to facilitate automated testing and review? For details on how to do so see http://www.vtk.org/Wiki/VTK/Git/Develop [^] |
(0033437) Marcus D. Hanwell (developer) 2014-10-02 10:23 |
Looking at this now, should be pretty simply to fix up. |
(0033446) Marcus D. Hanwell (developer) 2014-10-02 10:44 |
Line 1958 in the current master has what looks like your code snippet, this is the only occurrence of VTK_CURSOR_DEFAULT, this call is in the SetCurrentCursor method - either that was changed in the meantime, or I need more information on the expected behavior. |
(0033447) Marcus D. Hanwell (developer) 2014-10-02 10:45 |
Please reopen if you can provide more information. |
2012-12-06 08:57 | Giuseppe D'Angelo | New Issue | |
2013-06-25 13:48 | Dave DeMarle | Note Added: 0031058 | |
2014-10-02 10:10 | Berk Geveci | Assigned To | => Marcus D. Hanwell |
2014-10-02 10:23 | Marcus D. Hanwell | Note Added: 0033437 | |
2014-10-02 10:23 | Marcus D. Hanwell | Status | backlog => active development |
2014-10-02 10:44 | Marcus D. Hanwell | Note Added: 0033446 | |
2014-10-02 10:44 | Marcus D. Hanwell | Status | active development => backlog |
2014-10-02 10:45 | Marcus D. Hanwell | Note Added: 0033447 | |
2014-10-02 10:45 | Marcus D. Hanwell | Status | backlog => closed |
2014-10-02 10:45 | Marcus D. Hanwell | Resolution | open => fixed |
