0013719 | ParaView | (No Category) | public | 2012-12-10 17:05 | 2016-08-12 09:59 | ||||
Reporter | David Thompson | ||||||||
Summary | 0013719: Many selection conversions have no effect. | ||||||||
Description | The following selection conversions do not work: a. Converting a (cell or point) (threshold or frustum or location) selection to a block selection does not select block(s) containing the points or cells. b. Converting a block selection to a (global ID or index) selection does not produce a list of points or cells in each selected block. All of the conversions above produce an empty selection of the new type. This is counterintuitive and undo/redo does not appear to include changes to the selection so there is no way to revert to the previous selection. | ||||||||
Project | TBD | ||||||||
(0038295) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-12-10 17:05 | David Thompson | New Issue | |
2012-12-10 17:05 | David Thompson | Assigned To | => Utkarsh Ayachit |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038295 | |
